f450 work truck....finally removing the dpf
#92
#93
There's the rub. It seems to be general concensus that to get an MPG increase you must be on a high tune. It also seems to be general concensus that you should not tow on a high tune. So, it would seem that for those who tow "monster trailers" the delete/tune would be of no help. Right?
#94
Hey Tex, what tune are you running? You using that 210 towing tune? Have you used any other tunes while pulling? How is she shifting? Has it banged into any gears or felt like it was stuck in between gears?
Hope you were able to get your fuel sorted out. Drop those fuel filters ASAP. You should (if you don't already) always carry with you a spare set of filters.
#96
#97
#98
#99
#100
just got back in from tampa fla....numbers to follow.....man its been a busy month!! since the 9-1-10 i have delivered or picked up in mississippi 2 times, bama, louisania 5 times, arkansas, new mexico, dallas, tampa fla. , illinois....and a ton of local stuff...i know im forgeting some stuff but i am to tired to care..see you guys later
tex
tex
#101
#103
#104
There's one guy on here claims 20+. Nobody believes him though. 20s hard to do in these heavy trucks and a 4x4 makes it even harder. I couldn't get 20 in my 7.3L and that was an extended cab short bed. Soo, in a couple words "probably not".
#105
I could get 20 in my 7.3 if I tried. New Orleans to Jax, FL on one tank baby!
My dad does it in his 7.3 Excursion too. He drives it like there's eggs under the pedals though....
With this engine being smaller in displacement than a 7.3 it would make sense to get less MPG... Peak torque is at a higher RPM, etc...
