I still haven't messed with mine more but I don't like the way it moves up when the shift lever hits it going into park. I don't really want to drill into the steering column to fasten it but maybe I have to.
Means you had your column apart George, where would be the best place to drill it? I really don't want to drill into something important.
i would pull the wheel and drill into the front so the pins would be hidden. other than that unless you are really leaning on the drill, i dont think there is anthin to hurt by the shifter. the other side has the muti function switch wires
Just use the little plastic push pins that should have come with the pod to attach it to the stock cover.
That's what I will use, just wanted to put them in a safe place..
Copy, there's really nothing under there you can hurt unless you go REALLY nuts with the drill. It's pretty easy to pop the top cover off so you can work with it easier.
this is an old thread, I didnt remember it. BTW WELCOME TO FTE.
Originally Posted by chicagodragon
there is a link on the first page, or jegs has em too. i had to trim the back of mine a little to get it to fit good. i was also upset when i found out it just sits on top and dont replace the top of the colume. i had my colume apart before i found out.
When I Installed it, it was moving, but instead of drill or anything else, I put a couple of drops of cyanoacrilato (spl?) between the pod and the stock cover and no more movement, or maybe you can use the doble faced tape instead.
I tried the 2 sided tape when I did mine, I'd just throw that stuff away. Use the push pins, or some kind of adhesive like you did.
