Lincoln 368 pics? need help....
all the 368's had ECU stamped on the block, also they never went to the late holly bolt pattern on the intake. the 368's all had the carb mounted lower in the intake for hood clearance. the 57-64 HD 332's used ECU blocks also, but they had late holly intakes and forged cranks. the lincoln block is 11 in. deck hight and 4.625 bore spacing, weights over 700 lbs. bigger and heaver than an FE. all lincoln based engines have two raised ribs on each end, one on each side of the hold down bolts. the 368's were 4.00x 3.66 and could enlarged to 430 cu. in. the HD 332's were 3.80x 3.66, HD 302's were 3.625x 3.66, also had forged cranks. edmunds and fenton made 2x4 and 2x2 intakes, cragar made a blower intake, i believe. they used the same lifters as a FE, hyd. in lincoln's and solids in trucks, also used gears instead of a chain in 302-332's so the cam rotates backwards.
WerbyFord
10-23-2023 09:17 AM
01F1504
11-30-2021 05:07 PM
strokin'_tatsch
Vehicles for Sale
09-01-2014 03:27 PM
RFAgrasshopper
06-06-2012 08:15 PM
