Cruise control stuck on, wouldn't turn off when stopped
My wife drove the truck to her mom's house yesterday morning and set the cruise at 43mph in 4th gear. She came up to a red light and tried to shut it off, but it wouldn't turn off. She tried the brakes and it wouldn't shut off. She finally took it out of gear, came to a complete stop and the RPMs were at 1800 just like they were when going 43mph. She tried to get it to quit doing that and finally the light turned green. As soon as she put it in gear, it quit. Of course she fails to mention this to me yesterday and I find out this evening.
Would that have anything to do with the Ford Dealership fix on the cruise control switch? Or just coincidence? It never did this before. Truck specs in sig. Thanks.
Is it possible the Clutch position switch is bad? Does the truck start without the clutch pedal? That should not allow cruise to engage. Additionally, there are three fail safes in the cruise cancel system. The first is the brake light switch, which cancels cruise when power goes to the brake lights. Second is the clutch switch which is 'supposed' to cancel cruise if the clutch is pushed in. Third is a brake pedal pressure switch which under pressure cancels the cruise. It may take a hard application of the brake pedal to set off the pressure switch... Those are the three areas I would look at
Update: When she was stopped at the light, she couldn't figure out how to kick the idle back down with the clutch depressed and stomping on the brake pedal, so she put it in 1st gear and it finally kicked down to idle.
WA.Ranger, I tried to make the truck do that last night and it wouldn't. It worked flawlessly every time.
I will try to start the truck w/o depressing the clutch today.
Where is the cruise control housing? If all three switches wouldn't cut off the cruise control, I think this sounds like a good place to start, but I could be way off.
The diaphram might be leaking internally and hydrolocking the switch.
Seen that sort of thing before for MANY years on hydraulic brake light switches.
Two years ago. I was on the thruway. Went to get off on the ramp.. hit the brake/hit the off.. Nothing. Kept on chugging. I proceeded on the thruway trying to get it off Cruise.. brake mashing and Off button pounding for 5 more miles.. Then it went off.. I never could get it to repeat. Always been a mystery to me...
https://www.ford-trucks.com/forums/7...ing-ideas.html
