All the fuses in the truck and under the hood are good. The wires are all tight at the switch.
PO told me it was made in mexico. Where is the sticker with place of orgin?
I meant are you living in Canada or USA. All super dutys are in Kentucky.
Pull the plug out the switch on the column and look at the contact inside the plug. see if any look burnt.
I have day time running lights. They are on anytime the key is on.
Did that when I had it apart and they all look fine.
1) your low beams work correctly.
2) BOTH of your high beams do not work, but your low beams turn off when you turn your brights on.
3) your "momentary" high beams do not work.
4) no fuses are blown.
This really narrows down your problem to a connector or broken wire. You don't have a short to ground, and the problem is somewhere between connector C202a and the place where the power wire to the high beams splits S113.
Time to get the volt meter out!!
I would start by pulling fuse 30 (or the equivalent for your year) and test for 12v at the fuse socket when you turn the brights on. If you get power you have narrowed the problem down to somewhere between C270h and S113. If no power then the problem is between C202a and C270b.
If you get power at fuse 30, try replacing it (just for giggles). I have had fuses go bad but still look good.
