51 F1 wiring
51 F1 wiring
I apologize if this has been asked before, but I searched and didn't find it.
I have the original flathead 6 and want to convert my 6volt wiring to a 12volt wiring setup. Anyone know of a good place to get a good basic wiring kit without draining the bank? I don't think I need a whole lot of circuits at all, taking it back to original as I can (with modern wiring).
Thanks for your help in advance!
If you're happy with the stock wire look, check out Sacramento Vintage Ford stock wiring kits. They're modern wire with cloth covering.
Six volt wire is twice as heavy as needed with 12V so the stock harness is all you need unless you're adding a bunch of accessories that require more connections. Your goal will determine which way is best for you.
Advantage to stock kit is the colors match up with the original harness schematics... makes it a breeze to rewire the truck.
silvertonguedevil
01-04-2020 07:42 AM
Mixer man
03-22-2015 07:28 AM
1954_NJ_F100
08-21-2012 10:35 PM
dylan1952
03-22-2007 08:55 PM
dylan1952
02-06-2007 11:18 PM
