2005 Excursion and 2011 F-250 Take Offs - Page 4 - Ford Truck Enthusiasts Forums
  #46
Old 07-06-2014, 09:12 AM
Mattb60 Mattb60 is offline
Mattb60 is starting off with a positive reputation.
OK, so forgive me
I have never been able to understand "wheel math"
I have 20 x 9 BMF Sere's with 35x12.50 Mickey Ts
My BMFs are a -5" backspace and -4.5" is what is required to keep from rubbing the front leafs at full turn
The 2" spacers will push everything out 2" ,right ?
An earlier post seemed to indicate that these will not stick out beyond the fender wells.
  #47
Old 07-06-2014, 09:54 AM
tselden tselden is offline
tselden is starting off with a positive reputation.
So are the stock studs longer than 2" and need to be shortened?
I have not seen that on other post's.
  #48
Old 07-06-2014, 09:59 AM
Apocalypse's Avatar
Apocalypse Apocalypse is offline
Apocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputation
  #49
Old 07-06-2014, 10:32 AM
That helps. Thank you.
I have read many posts now, but still struggle with one issue.
Help me understand wheel geometry.
I know this is backwards from the correct mounting procedure, but hear me out.
If you were to imagine the wheel spacer already mounted to a newer Ford OEM wheel with 4" of back spacing and now you have only 2" due to adding the spacer, haven't you just changed the geometry on the wheel to be more in line with a wheel made for the vehicle (not using adapters)?
It seems like common sense that you are not really putting your family or rig in jeopardy by using spacers. Unless the spacers have now created a weak point and could shear off under a heavy load.
  #50
Old 07-06-2014, 10:55 AM
Apocalypse's Avatar
Personally and I think this has to do with each user on this forum it's all in how you use your X. I have the eBay HUBCENTRIC spacers and love them. They were 1/3 the price and are made just as well. However I have a 2wd and the 5.4 PLUS I don't tow. So I am at the complete opposite end of the spectrum from the better half on here I'm what you call poor (see; eats shoes for dinner) so I buy what I can afford and do the best that I can If I could afford a diesel or a 4wd I would never have gone with the eBay spacers, but then again I wouldn't have been in the same income bracket.
  #51
Old 07-06-2014, 07:10 PM
This may really be reaching.
Can anybody with 2" wheel spacers post a pic of how far their tires sit out and list whether they have 8", 9" or 10" wide wheels ?
  #52
Old 07-06-2014, 11:33 PM
Apocalypse's Avatar
We all have 2 inch spacers if we're running the newer wheels and the OEM wheels sit where the wheels sit now. The spacers just put them back where they are supposed to be. It doesn't change anything at all, just the backspacing.
  #53
Old 07-06-2014, 11:36 PM
Apocalypse's Avatar
  #54
Old 07-07-2014, 06:30 PM
So if I have 20x 9 wheels and I add 2" spacers my tires WON'T stick 2 " further out ?
  #55
Old 07-07-2014, 09:37 PM
Apocalypse's Avatar
Well if the backspace is correct then yes they will, but if they are for a newer Ford then no they won't.
  #56
Old 03-11-2017, 07:51 PM
grnrngr grnrngr is offline
grnrngr is starting off with a positive reputation.
I don't want to use spacers, I do want to swap wheels and style isn't very important to me, is there a list somewhere of which years are directly interchangeable? Basically will '97 wheels bolt straight onto my '03?
  #57
Old 03-11-2017, 08:43 PM
IMASAP's Avatar
IMASAP IMASAP is offline
IMASAP has a brilliant futureIMASAP has a brilliant futureIMASAP has a brilliant futureIMASAP has a brilliant futureIMASAP has a brilliant futureIMASAP has a brilliant futureIMASAP has a brilliant futureIMASAP has a brilliant futureIMASAP has a brilliant futureIMASAP has a brilliant futureIMASAP has a brilliant future
Quote:
No. 97 wheels are a 8 on 6.5 stud pattern, and the 03 has an 8 on 170mm stud pattern.
Also, with 2" spacers, the 97 wheels will stick way out.
  #58
Old 03-12-2017, 11:00 AM
WE3ZS's Avatar
WE3ZS WE3ZS is online now
World Famous Mod
WE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputation
'99 through '04 Super Duty and Excursion (including '05 on the EX) wheels will directly interchange with your EX without the need for spacers. All of them with the exception of the '04 only SD 18"s will be the same 16" size that you had stock without much variation in width. The SD wheels from '05 on all have a different back spacing that requires the spacers to fit our EXs correctly.
  #59
Old 03-26-2017, 05:34 PM
gapman789 gapman789 is offline
gapman789 is starting off with a positive reputation.
Quote:
Great thread....great info.
My first thoughts are to get '04 SD OEM wheels and level the front with an 'extra' spring? (if i've read that right).
  #60
Old 03-26-2017, 07:08 PM
WE3ZS's Avatar
World Famous Mod
Not all '04 OEM SD wheels are the same though, most of the pickups that year had the same wheels as our EXs. Only certain pickup trim packages came with the 18" wheels, this thread will help to explain what they are where they came from.
https://www.ford-trucks.com/forums/1...excursion.html
As far as the front suspension.......... You have tons of options depending on what exactly you are wanting end up with. Check out the Tech Folder at the top of the EX forum page for more info on suspension options.
Will a 2010 or 2011 F250 bed fit on a 2005 F250? 1sicksrt8 1999 to 2016 Super Duty 16 07-07-2017 05:02 PM
2014 20" Take off Rims on a 2005 F250 Mudman 1999 to 2016 Super Duty 7 05-27-2017 09:46 AM
Taking off just the tail pipe?? DeeDubz 6.7L Power Stroke Diesel 5 04-24-2017 09:41 PM
2008-2011 Factory Tow mirrors on a 2005??? SaleenS281 1999 to 2016 Super Duty 9 01-03-2017 01:15 PM
Will a new F250 Steering Wheel fit a 2005 EX? PI360 Excursion - King of SUVs 16 04-11-2016 07:13 PM
Tags
07, 2011, bolt, edition, excursion, f250, fit, ford, high1, oem, pattern, special, takeoffs, trucks, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
