48-50 Rear Cab Mount Question - Page 4 - Ford Truck Enthusiasts Forums
Old 08-21-2010, 06:14 AM
GreatNorthWoods's Avatar
GreatNorthWoods
GreatNorthWoods is offline
GreatNorthWoods is a name known to allGreatNorthWoods is a name known to allGreatNorthWoods is a name known to allGreatNorthWoods is a name known to allGreatNorthWoods is a name known to allGreatNorthWoods is a name known to all
Originally Posted by Mervy49 View Post
You will, ( maybe) have some problems getting the inner fenders, running boards to fenders etc, to fit properly since you raised the rear cab mounts up on the frame.
Perhaps, but that's why I decided three inches was too high and went with roughly one inch or less. The height didn't change up front so front/inner fenders should not be a problem and nothing attaches to the cab in the rear so I doubt if running boards will be a problem either...
  #47
Old 08-23-2010, 06:47 AM
hotrodbob51
hotrodbob51 is offline
hotrodbob51 is starting off with a positive reputation.
Ordered all new mounts hardware and dogbones the new type. Minw where shot. The cab looks great. Took it off the frame for now going to paint the frame under the cab and the bottom of the cab.
  #48
Old 08-26-2010, 01:38 PM
GreatNorthWoods
Originally Posted by ALBUQ F-1 View Post
Could you take a picture from the side?
Ross, here's the picture I promised...
  #49
Old 08-26-2010, 10:09 PM
Mervy49's Avatar
Mervy49
Mervy49 is offline
Mervy49 is a name known to allMervy49 is a name known to allMervy49 is a name known to allMervy49 is a name known to allMervy49 is a name known to allMervy49 is a name known to all
In this pic the cab/box proportions seem to be fairly close.....
  #50
Old 08-26-2010, 11:32 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputation
Is the bed bolted down yet? Looks a little far back, but height is correct.
  #51
Old 08-27-2010, 06:34 AM
GreatNorthWoods
It's not finally bolted down but it's where it will be when it is. It is bolted into the stock frame holes. Actually, I'm pretty satisfied with the spacing now even though it's a little wider at the bottom. At least the cab and front bed panel aren't touching like they were...
  #52
Old 08-27-2010, 08:12 AM
WMF6
WMF6 is offline
WMF6 is starting off with a positive reputation.
Don't know if this is a common problem with Bonus Builts but could the frame be sagging? Just wondering if the truck had previous owners who habitually overloaded it.
  #53
Old 08-27-2010, 01:59 PM
GreatNorthWoods
That's quite possible. It's a 61 year old truck. At that age we all sag a bit...
  #54
Old 08-27-2010, 02:38 PM
ALBUQ F-1's Avatar
ALBUQ F-1
postin' fool
Refer to the Dagmar thread for more on that....
  #55
Old 08-27-2010, 11:53 PM
51PanelMan's Avatar
51PanelMan
51PanelMan is offline
51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all
Plus we get our "Batman" wings with age.
  #56
Old 11-14-2017, 11:14 AM
yosemite98's Avatar
yosemite98
yosemite98 is offline
yosemite98 is starting off with a positive reputation.
Originally Posted by rb48f6 View Post
Vern~
Here are 2 pics I just took of the right side cab underside front to back and then back to front. It's a '48 F6, F1-F6 all mount the same as far as I know. And this cab (to best of knowledge) has not been taken off the frame in 62 years........ (And it's all that's on the top side of the frame now.)
Good post and info here.
Mine looks the same, image below. Now that the truck is running, I'm going back to what I was doing 4 months ago, making the ride a bit smoother and fixing the hole in my floor pan. However, I noticed the hole in the floor pan is likely partially due to the entire cab sitting on the frame so I need to fix that before I get to the floor pan, no wonder it's such a rough ride!
I think I'll start with the rubber pads kit from either midfifty or macs to see if that helps as the rubber in rear is missing, and the front mounts are clearly barely there. If that doesn't raise it I may have to figure something else out.
1948-52 Ford F-100 Cab Mount Rubber Pad & Washer Shim Kit 48-52 Front & Rear (no Bolts) - 7C-5400-SS
https://www.macsautoparts.com/ford_t...1-thru-f3.html
  #57
Old 11-14-2017, 12:51 PM
GreatNorthWoods
Thanks Yosemite! I asked that question 7 years ago but late is better than never! That truck was finished and sold in 2014.
  #58
Old 11-14-2017, 03:37 PM
yosemite98's Avatar
yosemite98
Haha, yeah... I was just looking into fixing my floor pan and saw the cab was on the frame and likely caused some the floor pan issue to begin with, and then found this post when trying to figure out what it's supposed to look like. Even 7 years later it's good info!
Hopefully you have a new project.
benbuilder
10-28-2017 04:52 PM
jniolon
09-24-2017 12:32 AM
hail destroyer
07-14-2017 05:40 PM
paintubturner
04-19-2017 12:20 PM
mofoco1
11-02-2016 10:40 PM
Quick Reply: 48-50 Rear Cab Mount Question
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
