not real familiar with all the ford trannys
Old 08-09-2010, 11:43 PM
92-150man's Avatar
92-150man
92-150man is offline
ive been trying to learn all i can about the different trannys put in our trucks from other threads but i still cant get the hang of it..but i have a 92 f-150 xlt 4x4 5.8 liter engine thats automatic with overdrive. could somebody inform me about what tranny i have and any stuff i should know about it? when my tranny goes id like to put a 5 speed in it, any idea which 5 speed tranny would be easiest to put in it? and would i have to do any computer swapping or other electrical stuff? thanks for any info and help guys!
Daniel
Old 08-09-2010, 11:49 PM
Torky2's Avatar
Torky2
Torky2 is offline
E4OD. Can't help on 5-speed ideas.
Old 08-10-2010, 12:02 AM
andym's Avatar
andym
andym is offline
Yeah you have an E4OD. If you are really careful with your truck you can use an M5OD but you really want a ZF 5 speed because they are much stronger.
Old 08-10-2010, 12:08 AM
pro70golfer14's Avatar
pro70golfer14
pro70golfer14 is offline
ZF was the second best thing I ever done to my truck. Go for it. It is just a good weekends worth of work.
Old 08-10-2010, 04:48 PM
92-150man's Avatar
92-150man
so a ZF tranny will directly bolt up to my 351 block? and i wont have to do any rewiring? and is there any different types/models of ZF transmissions or is that the type/model?
thanks guys,! daniel
Old 08-10-2010, 04:58 PM
EPNCSU2006's Avatar
EPNCSU2006
EPNCSU2006 is offline
It'll take a weekend if you have all the parts needed before you start . There were three versions of the ZF: small block gas, big block gas, and diesel. You will want the small block one for your 351 (S5-42, found in 300 six cylinder trucks and 351 trucks '88-'94). There was also a newer model (S5-47 '94-'97) that likewise had three configurations. I swapped manual to manual, so I'm not sure what is involved going from automatic to manual.
Browse through ZF's website for more information: http://www.zf.com/na/content/en/nort...cement_us.html
Old 08-10-2010, 09:28 PM
92-150man's Avatar
92-150man
Browse through ZF's website for more information: ZF Friedrichshafen AG | Service Portfolio
thanks for all the info! will the S5-42 be bolted to a 5.0 motor truck, years 88-94 also?
Old 08-11-2010, 05:35 AM
EPNCSU2006's Avatar
EPNCSU2006
As far as I know, Ford never put the ZF behind the 5.0, it was only the 300 and 351 in F250s and heavier trucks (except for '88 F150s according to ZF) that were paired with the small block ZF from the factory.
Old 08-11-2010, 08:27 AM
Alvin in AZ's Avatar
Alvin in AZ
Alvin in AZ is offline
Originally Posted by 92-150man
...have to do any rewiring?
daniel
There is a little bit of re-wiring, but it's mostly just un-wiring tho. :)
Best way to go is to get a parts truck ...or just get another truck! ;)
Since I was wanting a ZF-Bronco and was willing to rebuild the ZF
too, the parts truck idea worked out good for me. YMMV on that.
You'll need a manual computer (EEC) and a jillion other little things.
Like:
- whole pedal assembly, the automatic is plain ol' different :/
- manual steering column and speedometer block-off plate (want?)
- crossmember, the auto crossmember "can be made to work"
...(but, Ford changed it for a reason)
- flywheel and pilot bearing (I'm using a 6003 sealed ball bearing)
- clutch master cylinder and its line can be bought new for cheap
- etc
How serious are you about this swap? :)
If you're serious, first thing, get a full set of Ford Shop Manuals for
the year you'll be working with, they'll include the wiring diagrams.
Alvin in AZ
Old 08-12-2010, 09:26 PM
92-150man's Avatar
92-150man
Like:
- etc
Alvin in AZ
id really like to swap it if i have the money when my auto tranny goes..having the money will probably be determining factor along with time..im sure you all know how it goes..lol
twstr
47
01-17-2018 01:58 AM
dalberti
N. California Chapter
06-21-2015 11:34 PM
ferrousFord
04-09-2015 07:12 AM
daniel19794x4
01-17-2015 10:53 AM
danielb987
1947 and Older Ford Trucks
06-30-2014 02:34 PM
Quick Reply: not real familiar with all the ford trannys
