rear end and drive line chatter
Old 08-09-2010, 07:31 PM
ktp1942
ktp1942 is offline
ktp1942 is starting off with a positive reputation.
my 350 drw long bed has a chatter when taking off pulling my 14k toy hauler worse if in a turn took it to dealer today there is aservice bulletin on diff chatter on limited slip straight line chatter is to be deturmined but drive line angle under load is suspected has any one else had or heard of similar problem
Old 08-09-2010, 10:56 PM
roadtech
roadtech is offline
roadtech is starting off with a positive reputation.
Rear end chatter
Hi, just to let you know you are not the only not the only one out there with the issue. I'm on holidays right now pulling my 5th wheel and when I lay into it I'm getting the same feeling. I will have to speak to the dealer when I get back.
Old 08-10-2010, 08:15 AM
senix's Avatar
senix
senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
this is a driveline angle issue. Happens on 08-10 models as well. When you put that much in the bed of the truck, it sags too much.
Product of weaker springs. So helper springs or airbags for those heavy loads will take care of the issue.
preference to the airbags with onboard compressor. Then you can air up tires too.
Old 08-10-2010, 08:39 AM
rickatic
rickatic is offline
rickatic has a great reputation on FTE.rickatic has a great reputation on FTE.rickatic has a great reputation on FTE.rickatic has a great reputation on FTE.
I pull a 13000 pound fiver that sets my truck down to level. I have not noticed any rear end chatter in 3500 miles of towing it.
Tectron1
04-10-2015 10:54 AM
daningraham
11-26-2014 05:11 PM
CSIPSD
07-06-2014 11:34 AM
78ford351m
34
02-16-2009 05:44 AM
ewellman
10-23-2004 10:12 PM
Quick Reply: rear end and drive line chatter
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
