Lug Nut Differences F250, F350 DRW, and F350 SRW - Page 3 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Reload this Page >
  #31
Old 01-03-2018, 11:00 AM
1sweetride72
1sweetride72 is offline
1sweetride72 is starting off with a positive reputation.
I have an F250 4x4 with a 1ton front axle(1974 frame)
Mine has the 9/16 x 18tpi studs. I broke off 5 count-em studs. After taking a small sledge hammer to them, I was able to pound them out w/o too much trouble ( sorry pops ) but have no way of putting the new ones back in except maybe with a c-clamp between the new stud and the front of the housing. Is
  #32
Old 01-03-2018, 11:03 AM
1sweetride72
This website
I have tried three times now to finish hunting and pecking and. it will not let
  #33
Old 01-03-2018, 11:06 AM
1sweetride72
Frustrated first time user.
Three wasted tries to finish before site scraps my input.
  #34
Old 01-03-2018, 11:29 AM
SaddleBronc's Avatar
SaddleBronc
SaddleBronc is offline
SaddleBronc is starting off with a positive reputation.
I'll guess at your issue based on what you said already, and tell you what I've done in that situation. Find something to use for a sleeve....maybe a socket if you have a large drive, or other short stout piece of pipe. Put the new lug bolt in from the back, insert the sleeve over the threads and put a lug nut on backwards (flat side to sleeve).
Tighten slowly using lots of lube and patience, and this should pull the bolt into the rotor/drum. Long breaker bar or good air wrench helps.
Dace
10-26-2017 04:12 PM
Jesse73iditurbo
Aftermarket Products
08-29-2017 10:00 AM
mdayz28
1999 to 2016 Super Duty
04-10-2017 01:06 PM
PSU4ME
12-27-2016 06:03 PM
Oldchap
07-10-2016 12:20 PM
Quick Reply: Lug Nut Differences F250, F350 DRW, and F350 SRW
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
