1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
turn signal problem 2004 F250 6.0L
Old 01-06-2016, 04:05 PM
Lewis Agen's Avatar
Lewis Agen
Lewis Agen is offline
no buzzing or clicking from my flasher relay relay
Old 01-06-2016, 04:06 PM
Lewis Agen's Avatar
Lewis Agen
my relay is under the hood in the engine compartment
Old 01-06-2016, 08:34 PM
jh818's Avatar
jh818
jh818 is offline
If your hazard lights click, it's not your flasher. Might be your stalk (switch).
Old 01-07-2016, 05:45 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is online now
Unlikely, but, since you failed to explicitly identify what you're working on, it's not possible to offer specific advice except for you to fill in details.
Old 05-24-2018, 10:38 PM
Dcarmic's Avatar
Dcarmic
Dcarmic is offline
New to this.
2006 F250 4x4 I’m having the no turn signal problem also flashers working but no turn signal. I was able to reach and change the blue flasher by dropping my storage box. Fuses are all good. Tried to remove the steering column cover but was stop by rain.
Any advise appreciated
Old 08-04-2019, 12:57 PM
Michael Mallinson's Avatar
Michael Mallinson
Michael Mallinson is offline
. Believe it or not it is fuse number 27.
Originally Posted by kodiak_f250
ok, its fixed
all I did after replacing the relay is: press the hazard lights button on top of the steering wheel, and that reset something, not sure what, maybe the old broken relay kept something stuck, but after pressing that on and off, the turn lights now work and they show up in the dash as well, cool :- )
glad that all it took
almost 152,000 miles, this is the only thing gone bad so far, knock on wood
Your problem is Fuse 27 interior box
The following users liked this post:
Old 06-18-2020, 04:45 PM
joshua Mym's Avatar
joshua Mym
joshua Mym is offline
Ford F-250 6.0
wow you knew exactly what he’s Turning signal problems was , I had the exact same problem and since I was riding all comments I found out your was the right one. I just changed fuse 27 which is blue15 and problem or headache solved 😁. Who knows how much the mechanic would have had charged me. Thank you so much
stecz
01-11-2024 05:35 PM
AlSa
2009 - 2014 F150
10-22-2019 06:53 PM
tylers65
01-26-2014 03:10 PM
Granpa's76
10-03-2013 11:10 PM
thefnswits
12-21-2007 07:55 PM
Quick Reply: turn signal problem 2004 F250 6.0L
