What did you do to the X today?
  #10501
Old 11-02-2012, 10:57 AM
Woodfoot's Avatar
Woodfoot
Woodfoot is offline
Originally Posted by Jarhead97
I've heard too many stories of desperate people (I mean prior to Sandy) who don't even bother syphoning the gas. They just drill or rupture the tank, drain it into buckets and load it up into the back of their van or truck..
Very true, I also have a locking cap, 44 gallons of diesel is no where near cheap. Keeps the honest people honest. I have a family that owns a custom machine and welding shop, I hav having him weld up a shell out of 1/4 inch steel to fully enclose my fuel tank. Will help stop any attempts but also add off road protection
  #10502
Old 11-02-2012, 11:10 AM
Jarhead97's Avatar
Jarhead97
Jarhead97 is offline
That's a great idea. At $160-$175 for a full fill up, not bad investment protection for just adding a little extra weight...
  #10503
Old 11-02-2012, 12:57 PM
Tom's Avatar
Tom
Tom is online now
Trailer is almost loaded up, so I hooked it up and got my WD setup figured out. Had to move the battery box on the trailer back a few inches to make the WD bracket work, and I also installed my B&W 24K ball. Have the spring bars cranked pretty hard, and once we're fully loaded tomorrow I'll be getting a good tongue weight measurement from the local scale for fine tuning.
  #10504
Old 11-02-2012, 01:00 PM
archtaan's Avatar
archtaan
archtaan is offline
Could you take a few pics of the WD setup you have? I have a V-nose as well and cannot find a good WD setup because of the room issues with a v-nose.
  #10505
Old 11-02-2012, 01:35 PM
Tom's Avatar
Tom
Tom is online now
I feel your pain, my last trailer was unable to use a typical WD setup due to the front of the V was over the part of the frame where the WD hardware needs to go. On that particular trailer I ended up paying a trailer shop to weld hooks onto the frame, and setting up the hitch required using a floor jack to lift the ends of the spring bars to hang the chains on the hooks. It sucked, but it worked. I'll try and find some photos of the setup for you, give me a bit.
After going through all that with my last trailer I ordered this one with an extended tongue to properly allow for the use of a WD hitch. That extra 18" of tongue was the best $100 I've ever spent! Other than moving the battery box, which took all of five minutes, all I had to do was clamp on the brackets and use as directed. So unfortunately pictures of my current setup probably won't help you.
  #10506
Old 11-02-2012, 02:14 PM
gr8scott72's Avatar
gr8scott72
gr8scott72 is offline
I've ordered two trailers and had both made with the extended tongue. I didn't need it for a WD but wanted my toolbox on the tongue. Money well spent!
  #10507
Old 11-02-2012, 03:29 PM
acf6's Avatar
acf6
acf6 is offline
Ex and trailer look great, are you loaded to move to CT?
  #10508
Old 11-02-2012, 03:58 PM
Bdanger231's Avatar
Bdanger231
Bdanger231 is offline
Just rolled over 280,000 miles today. About to change ball joints, brake pads all around, shocks front and rear and front end alignment. As much as I want a diesel this 5.4 Triton is a beast. MPG's suck but so does the price of diesel. I'm gonna take this thing to 500,000 if it will take it....
  #10509
Old 11-02-2012, 04:29 PM
AzPatMan's Avatar
AzPatMan
AzPatMan is offline
That's what Chips/Tuners and MOD's are for!
Some of the simplest mods - provide free MPG improvement (ie, ZooDad Mod)
  #10510
Old 11-02-2012, 04:31 PM
Bdanger231's Avatar
Bdanger231
Any other mods you would suggest for the 5.4? I'm looking up ZooDad now...Thanks!
  #10511
Old 11-02-2012, 04:36 PM
BroncoRN's Avatar
BroncoRN
BroncoRN is offline
Figured out ebrake light issue and rear hatch lock actuator.
  #10512
Old 11-02-2012, 05:14 PM
Misky6.0's Avatar
Misky6.0
Misky6.0 is offline
Have you ever figured out how much gas you buy going 280k miles at 10 mpg? The cost of the ex
Pails in comparison.
  #10513
Old 11-02-2012, 05:19 PM
Bdanger231's Avatar
Bdanger231
Yeah this X didn't cost me much...I traded a 1997 Mustang GT and a 2002 Ford Escort for it...
  #10514
Old 11-02-2012, 05:22 PM
acf6's Avatar
acf6
acf6 is offline
Since ive done about everything to improve MPG on a 5.4.. here it is
Zoodad mod - free and 0 mpg, but free so its ok
5 Star tunes - $379 and maybe a SLIGHT mpg increase, and i run in 87 performance
Gibson headers - $450 and again, maybe a SLIGHT mpg increase
SPD y pipe - $150 and probably only noticable mpg gain
Cat back MBRP dual exhaust - again, maybe a slight gain
i think biggest help for me would be gears... but i dont plan on keeping the truck for long so im not going to invest the money
  #10515
Old 11-02-2012, 06:47 PM
Tom's Avatar
Tom
Tom is online now
Yup, we finish loading tomorrow, and I drive out on Monday!
Quick Reply: What did you do to the X today?
