What did you do to the X today?
#9751
i took mine out to run across town but i also checked out to see what if any damage this latest wind storm brought. nothing at my house but there is power outages, flooding, downed trees across town.
took this heading up the hill on a back road.
9/16/12 wind/rain storm, Anchorage, AK - YouTube
#9752
#9754
Received 5,131 Likes
on
#9756
Replaced the belt on mine, it hadn't been replaced since 2008 and needed it bad after looking at it.
I also replaced the (somehow) leaking Engine Coolant Temp sensor. I went to O'reilly and bought the more expensive of the two only to find that it doesn't work.
It turned out the cheaper of the two available sensors is the one for the dash gauge and the more expensive one is for the PCM.
#9757
I could never figure out why vehicle manufacturers use two sensors for the same fluid like mentioned instead of just one. I mean if you are looking for places to save money, weight, and complexity wouldn't reducing multiple sensors be a good one?
One sensor for the PCM/ECU/EFI unit and then from there the electronic engine control unit can send a signal to the gauge or whatnot. Same with radiator fans, why not just use the PCM sensor that is already there and have the PCM trigger a relay to turn the fans on. Not a whole extra wire, relay, sensor system.
#9758
#9761
Well if there was just one sensor for the PCM and gauge I guess you would know by the gauge when that one sensor is bad.
#9764
I've heard PB Blaster recommended a lot, and had pretty good results with it myself, so I was surprised by some test results I found posted at FIFTH AVENUE. (I found that link in a thread on Penetrating Oil Test - Bob Is The Oil Guy.) According to this test, PB Blaster was only slightly better than WD-40 for loosening rusty bolts.
#9765
(bold mine)
