What did you do to the X today?
#616
#617
Rear Strobes...installed by drilling a 1" hole in the center of the 'top' reflector housing, then 2 holes 1 1/4" apart for securing the bulb:
Put the flasher unit forward of the jack. Made 2 brackets from aluminum and mounted to the floor of the truck:
Routed the passenger side strobe wire right through the giant rubber gromment...the driver side strobe went down to the underside, then through that rectangular tube that supports the floor (perfect placement and relatively protected), then up through the driver side (look under and you'll see a plastic shield - drilled through that) then through a mysterious opening:
The strobe wires are VERY heavy, so I'm not too worried about chafing of the wire insulation, but I will check them occasionally to be sure.
Ran the ground, hot and trigger wire under the passenger side sills, across the front floorboard to the new fuse block.
Can't WAIT for the RiffRaff center console!!
#620
Installed ceramic-coated Int'l bellowed up-pipes after work yesterday. Had all the bolts on old up-pipes off in literally 5 min . Gotta love a southern beauty - even if the old girl has 255k miles on her!!! Then the turbo and pipes were out in about 45 min. 15 min later the purty new up-pipes were (loosely) bolted in place. After another 2.5hrs , I had the babies butt hooked up... It was maybe another 30 min before I finished after that.
FWIW, I didn't do anything different with babies **** - I just finally lifted it up into just the right spot and it went together EASY.
So, 6mi drive to work this AM and my initial impressions. As soon as it was warmed up I hammered it and it spooled ALOT faster than it did yesterday and at almost 25psi blow a CAC boot before I limped the rest of the way to work. It was past my bedtime long before I finished last nite and I did not clean the boots the way I normally do.
#621
#622
PICTURES OF ROOF RACK - ASAP!!!! I've been thinking about custom racks since I got the X...
#623
He hasn't called yet so I guess it's not done. It's gonna be just like one of those hitch-hauls that u put in a 2" receiver. But this one is gonna be 7'x4.5'. Just 2"angle and mesh. I'm mounting it on a set of Yakima bars. I'll get pics as soon as I get it and put some bedliner in a can on it.
#624
#625
#626
Not electrically inclined enough to know the technical terms...
#628
#629
#630
