What did you do to the X today?
This post discusses them and has pictures of them, inside the trans. Pan off, valve body removed and there they are.
https://www.ford-trucks.com/forums/1...into-gear.html
hopefully this counts as a topic post, what a I did to the X this morning was in-vision it having this rear door setup.
https://jalopnik.com/the-2019-ram-15...swi-1832393157
Replaced the PCV and rubber grommet, oil filter and fresh oil. Attempted steering box repair but as soon as I removed the steering shaft I saw that the leak was not from the input shaft seal but rather from the middle of the box where it looks like it comes apart. I guess the gasket blew out. I guess I'm replacing the box and probably the lines as well. I think I read somewhere that someonereplaced theirs with one from a newer super duty, is this possible and is it actually better?
Yeah, I saw that, just curious if anyone's actually done it and how difficult it was. It's most likely the route I'm going to go as it's the cheapest way to go. I'm going to pull the box and disassemble first to make sure there's no serious damage to the internals.
I posted this in the Craigslist thread. Might be just what you need: https://newyork.craigslist.org/que/c...913896432.html
Column Shifter Bushings
I replaced both column shifter bushings in an attempt to eliminate the sloppy feel of the shifter. Both bushings were disintegrating and there was a lot of black dust and debris all over the shaft and surrounding areas.
Didn't help the shift feel quality much. A little maybe. But it was a let down.
Job didn't take more than an hour. Would I do it again? Probably not, unless I was bored and had nothing else to do. ; )
