What did you do to the X today?
  #49936
Old 05-15-2019, 04:29 PM
Y2KW57's Avatar
Y2KW57
Y2KW57 is offline
Y2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputation
Stebs
Were those studs fine thread or course thread? (The changeover occurred in 2002)
  #49937
Old 05-15-2019, 04:56 PM
geekwithoutacause
geekwithoutacause is online now
geekwithoutacause is starting off with a positive reputation.
Originally Posted by wildstang View Post
I ordered this from Amazon
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
seems to work good so far.
old on top, new on bottom
that is a crappy picture. I'll have to do a different one later
oh nice. I still have a roll of latex I wanted to use on my 2014 f250 but I might just go this way.
You still like them ? I can't believe my 2014 w only 49K on it already has rattling doors.
  #49938
Old 05-15-2019, 08:59 PM
wildstang's Avatar
wildstang
wildstang is online now
VT Chapter Ldr
wildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputation
So far they are still holding up but it has been less than a week but my dirt road is still rough and no rattling yet. I will know better in a year how they are.
Next rattle to take care of is the front sway bar
  #49939
Old 05-15-2019, 10:22 PM
geekwithoutacause
I checked my current ones and the truck does have the double chambers but the outer one is completely flat.....
  #49940
Old 05-16-2019, 07:20 PM
ford_model'a''s Avatar
ford_model'a'
ford_model'a' is offline
ford_model'a' is gaining momentum as a positive member of FTE.ford_model'a' is gaining momentum as a positive member of FTE.
How do you adjust your master cylinder?
  #49941
Old 05-16-2019, 09:45 PM
Flyboy1100
Flyboy1100 is offline
Flyboy1100 is a name known to allFlyboy1100 is a name known to allFlyboy1100 is a name known to allFlyboy1100 is a name known to allFlyboy1100 is a name known to allFlyboy1100 is a name known to all
Swapped my drivers side window switches with a supposed NOS ford part, i mean the box is dated for sure, and it feels a bit more clicky than my old switches, but it also might be slightly used and cleaned well. Never can tell with ebay, but when the current part is on an unknown eta semi permanent backorder dont have a lot of options. Not many new OEM switches out there right now....
ops check good though and appears to have fixed my issue
next will be vent window switches when they arrive. Once the roof heats up, they dont work any more until parking in the shade for a while or letting it sit overnight.....so something heat related. New OEM were 16/ea after shipping + tax
  #49942
Old 05-17-2019, 12:05 AM
Stebs
Stebs is offline
Stebs has a great reputation on FTE.Stebs has a great reputation on FTE.Stebs has a great reputation on FTE.Stebs has a great reputation on FTE.Stebs has a great reputation on FTE.
Course thread
  #49943
Old 05-17-2019, 05:33 AM
dualwheels66
dualwheels66 is offline
dualwheels66 has a great reputation on FTE.dualwheels66 has a great reputation on FTE.dualwheels66 has a great reputation on FTE.dualwheels66 has a great reputation on FTE.
When you take the master cylinder off the booster, you will see a small rod. With a pair of pliers in your right hand, grip the serrated rod, with a 7mm wrench in your left hand, turn the nut counter clockwise, you want to lengthen the rod. Try a half turn, then go for a test drive. If you turn it too far, the brakes will always grab, you don’t want that. There is a thread around here somewhere with pictures. I have done this on 3 different trucks with good success. The only reason to do this is if you have a lot of pedal travel before the brakes are applied. I adjusted mine 1 1/2turns, brakes feel good now.
  #49944
Old 05-17-2019, 07:19 PM
Y2KW57's Avatar
Y2KW57
Y2KW57 is offline
Originally Posted by Stebs View Post
Course thread
Thanks for the response.
It's probably too late, but I was going to suggest, since you also had to replace 25% of the lug nuts anyway, that you switch to the fine thread studs and nuts, as Ford later found it best to do.
I only mention this now for other readers who are considering new studs to preempt a problem like Stebs had.
  #49945
Old 05-18-2019, 07:58 AM
Tbug05LTD
Tbug05LTD is online now
Tbug05LTD has a very good reputation on FTE.Tbug05LTD has a very good reputation on FTE.Tbug05LTD has a very good reputation on FTE.
Replaced this piece that supports the air intake tube that connects to the IAC valve. Original broke when I installed the new IAC. My local dealership said it was obsolete but they located two down in Arizona.
  #49946
Old 05-18-2019, 10:15 AM
jdw1's Avatar
jdw1
jdw1 is offline
jdw1 is a name known to alljdw1 is a name known to alljdw1 is a name known to alljdw1 is a name known to alljdw1 is a name known to alljdw1 is a name known to all
Front end work!
New axle u joints
hub bearings
inner axle seals
ball joints
vaccum hose fittings
with 300xxx miles on the u joints the one on the drivers side locked up so as long as Im in there Im doing a complete service, 200xxx miles on ball joints, hubs, tie rods so its time for new!
  #49947
Old 05-19-2019, 02:58 PM
jdw1's Avatar
jdw1
jdw1 is offline
Getting deeper!
Yes, it’s getting a new steering damper too!
  #49948
Old 05-19-2019, 05:45 PM
gots_a_sol's Avatar
gots_a_sol
gots_a_sol is offline
gots_a_sol has a brilliant futuregots_a_sol has a brilliant futuregots_a_sol has a brilliant futuregots_a_sol has a brilliant futuregots_a_sol has a brilliant futuregots_a_sol has a brilliant futuregots_a_sol has a brilliant futuregots_a_sol has a brilliant futuregots_a_sol has a brilliant futuregots_a_sol has a brilliant futuregots_a_sol has a brilliant future
Drug home another non functioning vehicle on Friday lol
Then went riding/camping Sat/Sun
Fire ring is really just a suggestion
  #49949
Old 05-20-2019, 12:04 PM
jasonodsky's Avatar
jasonodsky
jasonodsky is offline
jasonodsky is a splendid one to beholdjasonodsky is a splendid one to beholdjasonodsky is a splendid one to beholdjasonodsky is a splendid one to beholdjasonodsky is a splendid one to beholdjasonodsky is a splendid one to beholdjasonodsky is a splendid one to behold
Fixed a broken exhaust pipe. It cracked between the cat and muffler, right at the up bend.
Fabricated a replacement 20 degree bend.
Failure was caused by stress on the pipe. The hanger at the front of the cat was disconnected so the weight of the cat bouncing around slowly weakened the joint.
Truck is is super quiet compared to what Ive been accustomed. I think it slowly gave way so I didnt notice how loud it had become.
Shop wanted to to charge me $100 for the fix. I repaired our with scrap material and 4 hours of my time. Win/Win
Broken exhaust in front of the muffler
Fixed, before welding
  #49950
Old 05-20-2019, 01:58 PM
Skip1970's Avatar
Skip1970
Skip1970 is online now
Skip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputation
looks like it needs a entire exhaust
Quick Reply: What did you do to the X today?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
