What did you do to the X today?
  #49636
Old 03-26-2019, 09:05 PM
copsey's Avatar
copsey
copsey is online now
copsey has a great reputation on FTE.copsey has a great reputation on FTE.copsey has a great reputation on FTE.copsey has a great reputation on FTE.copsey has a great reputation on FTE.
Finally dropped the tank and pulled the hitch to install the almost new one Nicmike was so gracious to bring to the MidWest. Also hoses down the whole undercarriage with Fluid Film to keep the wolves away. Will have nuts welded to the “non-removable” bolts tomorrow if all goes to plan and pick up the camper this weekend to get it ready for the spring summer and fall. Wife, kids and I cannot wait to get it out.
  #49637
Old 03-27-2019, 01:36 PM
SR-71Blackbird
SR-71Blackbird is offline
SR-71Blackbird is starting off with a positive reputation.
I put in new rear blocks to level the X out.
  #49638
Old 03-27-2019, 01:44 PM
lonnyallison's Avatar
lonnyallison
lonnyallison is offline
lonnyallison is starting off with a positive reputation.
Looks good! What are your before and after center of hub to fender measurements?
  #49639
Old 03-27-2019, 02:14 PM
SR-71Blackbird
I'm using late model wheels so I had to add 2" spacers. It's been a pain in the you know what but looks much better. I didn't measure before I added them but it looked really silly.
  #49640
Old 03-28-2019, 07:58 PM
Nicmike's Avatar
Nicmike
Nicmike is offline
Veteran/Sheepdog
Nicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputation
Changed out the engine mounting gaskets for the oil cooler. Front gasket has been leaking since fall. Finally can check that off my list...
  #49641
Old 03-28-2019, 10:11 PM
gots_a_sol's Avatar
gots_a_sol
gots_a_sol is offline
gots_a_sol has a brilliant futuregots_a_sol has a brilliant futuregots_a_sol has a brilliant futuregots_a_sol has a brilliant futuregots_a_sol has a brilliant futuregots_a_sol has a brilliant futuregots_a_sol has a brilliant futuregots_a_sol has a brilliant futuregots_a_sol has a brilliant futuregots_a_sol has a brilliant futuregots_a_sol has a brilliant future
Replaced a 1.5 year old Advance Auto rear caliper on Thursday as it was starting to seize up like the old one. Friday I drove down to FL and just came back on Tuesday. Mileage down was 18.2 holding it at 70 the entire way. First fill up on the way back was 17.5 with about 1/4 of that tank being city driving then doing 75-80 most of the way on the highway. Not horrible, especially compared to the V10 numbers I was getting.
  #49642
Old 03-29-2019, 07:07 PM
copsey's Avatar
copsey
Just buttoned up the hitch replacement. That fuel tank is a real pain in the a$$ without help. Even with only a few gallons in it.
  #49643
Old 03-29-2019, 08:37 PM
Nicmike's Avatar
Nicmike
Nicmike is offline
Veteran/Sheepdog
Did you use the "Egyptian" method?
  #49644
Old 03-30-2019, 05:33 AM
WE3ZS's Avatar
WE3ZS
WE3ZS is online now
World Famous Mod
WE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputation
He said he was by himself Mike, he didn't have the 150,000 slaves to help him!
I've had my tank out twice, I pump it dry before starting and for me the hardest part is controlling the floor jack handle for lowering with one hand while using the other hand to help keep the tank balanced on the jack pad. Having the 4"+ of suspension lift does make the job a little easier.
  #49645
Old 03-30-2019, 07:53 AM
Snowseeker's Avatar
Snowseeker
Snowseeker is offline
Snowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputation
April 1st is only days away! First day insurance goes back on the X which means I can pull it out any day now! Salt is pretty well washed off the roads, temps are nice, looks promising!
  #49646
Old 03-30-2019, 01:44 PM
charles adams's Avatar
charles adams
charles adams is offline
charles adams is gaining momentum as a positive member of FTE.
'05 Headlight swap
  #49647
Old 03-30-2019, 02:13 PM
thor363
thor363 is online now
thor363 is a name known to allthor363 is a name known to allthor363 is a name known to allthor363 is a name known to allthor363 is a name known to allthor363 is a name known to all
Doesn't that require a pile of bricks to stack as you drop it? Good advice compared to what I did!
  #49648
Old 03-30-2019, 02:30 PM
Nicmike's Avatar
Nicmike
Nicmike is offline
Veteran/Sheepdog
Very close. I use two stacks of 2x4x18" boards. Lower it on to the two stacks, then go side to side removing one block at a time. Reverse the process to put it back in. You can do this with half your brain and one arm.
  #49649
Old 03-30-2019, 04:05 PM
thor363
Due to senility, I barely pass that test!
  #49650
Old 03-30-2019, 07:43 PM
Flyboy1100
Flyboy1100 is online now
Flyboy1100 is a name known to allFlyboy1100 is a name known to allFlyboy1100 is a name known to allFlyboy1100 is a name known to allFlyboy1100 is a name known to allFlyboy1100 is a name known to all
what about motorcycle/atv jack? if i ever have too, that is my plan
Quick Reply: What did you do to the X today?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
