What did you do to the X today?
  #49546
Old 02-21-2019, 12:49 PM
SmackDaddy's Avatar
SmackDaddy
SmackDaddy is offline
SmackDaddy has a great reputation on FTE.SmackDaddy has a great reputation on FTE.SmackDaddy has a great reputation on FTE.SmackDaddy has a great reputation on FTE.SmackDaddy has a great reputation on FTE.
Yeah not much posting going on around here lately. I will be doing some write ups soon to fill in the gaps.
  #49547
Old 02-21-2019, 07:59 PM
Flyboy1100
Flyboy1100 is online now
Flyboy1100 has a great reputation on FTE.Flyboy1100 has a great reputation on FTE.Flyboy1100 has a great reputation on FTE.Flyboy1100 has a great reputation on FTE.Flyboy1100 has a great reputation on FTE.
brushed the snow off today.
yesterday bought a new FC975 fuel cap since the tether on mine broke. probably would have been a cheaper solution, but a new cap assembly was quicker
  #49548
Old 02-22-2019, 10:10 AM
unleashd's Avatar
unleashd
unleashd is online now
unleashd has much to be proud ofunleashd has much to be proud ofunleashd has much to be proud ofunleashd has much to be proud ofunleashd has much to be proud ofunleashd has much to be proud ofunleashd has much to be proud ofunleashd has much to be proud of
Finally, took off the cross bars on the roof.
  #49549
Old 02-22-2019, 10:46 AM
carbon coupe's Avatar
carbon coupe
carbon coupe is offline
carbon coupe has a spectacular reputation.carbon coupe has a spectacular reputation.carbon coupe has a spectacular reputation.carbon coupe has a spectacular reputation.carbon coupe has a spectacular reputation.carbon coupe has a spectacular reputation.carbon coupe has a spectacular reputation.carbon coupe has a spectacular reputation.carbon coupe has a spectacular reputation.carbon coupe has a spectacular reputation.carbon coupe has a spectacular reputation.
Yeah, I have a pile of parts/projects I need to do but the weather is crap and my building isnt started yet.
  #49550
Old 02-22-2019, 10:54 AM
ShelbyHauler's Avatar
ShelbyHauler
ShelbyHauler is offline
ShelbyHauler has a very good reputation on FTE.ShelbyHauler has a very good reputation on FTE.ShelbyHauler has a very good reputation on FTE.
i just posted up a near finished job of replacing my seat heaters and carpet here: https://www.ford-trucks.com/forums/1...l#post18498242
  #49551
Old 02-23-2019, 06:02 AM
unleashd's Avatar
unleashd
Swapped out the running boards from a '15 Platinum CC. My stock boards will be goin on the other white EX in the background.
  #49552
Old 02-23-2019, 08:51 AM
carbon coupe
Thats a great looking truck! Convinced me to go '05 front end and paint my cladding. Im going to pick up new doors tomorrow and hopefully selling some NOS OEM 01 front parts to get the 05 stuff.
  #49553
Old 02-23-2019, 09:06 PM
unleashd's Avatar
unleashd
I still need to get the bumper top plastic part and grille paint matched to the EX to complete that facelift. But this will have to wait until later in the year as funds are being held in escrow for other projects that take priority to keep the EX running better than looking good
  #49554
Old 02-28-2019, 10:31 AM
carbon coupe
Went to look at a pair of front doors for my truck yesterday. If you're replacing the doors, beware, the doors on the EX have an angled release handle on the inside. Anything 2008 and after is perfectly horizontal. there would be some fab work to get your stock door trim to fit properly. 2007 and older is correct for our trim. Just a heads up.
  #49555
Old 02-28-2019, 12:00 PM
unleashd's Avatar
unleashd
If you are getting a newer front door, why not get the matching inside panel as well?
  #49556
Old 02-28-2019, 04:21 PM
unleashd's Avatar
unleashd
2 people decided to brave this storm to meet up in Roanoke, VA to exchange some pleasantries for a few minutes and then head back home. ~500 miles round trip to meet with Chris 01__Excursion and pick up a set of Captains Chairs for the EX. Thanks Chris for meeting up with me halfway!! Hope you had a safe trip back home. Got home just as this white stuff started to stick.
This is s'posed to get pretty nasty later this evening.
PC: Chris. Now, to find an upholsterer to re-cover these seats!
01__Excursion ,
These came out great after a re-cover-y operation.
Next order of business will be to repaint the trim plastics and then figuring out how to fit a T55 under this metal plate to get the bolt out.
Is there a nut underneath that I can get to easier?
Never mind. Searching the forum is the best thing after sliced bread Here's how to get those bolts out.
  #49557
Old 02-28-2019, 06:09 PM
Ziess
Ziess is offline
Ziess is starting off with a positive reputation.
Put new 285/75/16 BFG All Terrains on her, got an alignment, and put new Bilstein 5100 shocks up front and new Bilstein steering damper on her. Drives like new, so much quieter and smoother than the old tires too. I'm happy!
  #49558
Old 02-28-2019, 06:32 PM
01__Excursion's Avatar
01__Excursion
01__Excursion is offline
01__Excursion is a name known to all01__Excursion is a name known to all01__Excursion is a name known to all01__Excursion is a name known to all01__Excursion is a name known to all01__Excursion is a name known to all
01__Excursion ,
Are those pics of your 60/40 middle row? Remove the side tan trims, flip up the seat portions, remove the hinge bolts, then the seat, then operate the seat slide to slide each 60, then 40 forward to get to that torx bolt. It's actually a T55 Plus. You can usually get it with just the T55, but the T55 is a loose fit for a reason, and if your bolt is somewhat frozen from the exposed threads on the underside, you risk snapping your T55, or damaging the Torx seat bolt.
Amazon Amazon
  #49559
Old 02-28-2019, 06:57 PM
unleashd's Avatar
unleashd
https://www.amazon.com/OTC-6192-TORX.../dp/B002YKG2R4
Yes. That's a pic of my 60/40. It was dark by the time I realized how easy those bolts can be accessed by sliding the seats forward So, this will be done over the weekend.
  #49560
Old 02-28-2019, 09:33 PM
wpnaes's Avatar
wpnaes
wpnaes is online now
wpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputation
Iím kinda disappointed Prakash, was expecting to see a French fry, some stale chips, cracker crumbs and a gummy worm under there.
Quick Reply: What did you do to the X today?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
