What did you do to the X today?
I got a few things done this weekend. I installed some new tail lights. They are fantastic! Look great, they are much brighter than stock and no hyper flash.
I installed some new infinity speakers in the front and middle row doors. What an amazing sound upgrade. Even without an external amp driving them they sound amazing compared to the stock speakers. While I had the doors panels off I lined the inside of all doors with sound deadening material (like dynomat) as well, and gave them a good coat of fluid film on the inside.
I finally got my brake controller installed
I also installed an aftermarket android HU, the ATOTO A6. I'm very impressed with it so far. Finally having streaming music again is fantastic. Installed complete with back up camera, gps antenna, and fully integrated steering wheel controls.
See my write up for SWC integration here https://www.ford-trucks.com/forums/1...o-install.html
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
5.4 2v with 4R100 Trans
6.8 2v with 4R100 Trans
7.3 PSD with 4R100 Trans
6.0 PSD with 5R110 Trans
As far as electronics, the Excursion was most definitely CanBus by at least 2003 models with the 6.0 and 5R110 trans. It's part of the reason Ford swapped from GEM to the VSM module. Luckily the radio in the Excursion wasn't part of the CANBUS like later Ford models (2005+) did
no Excursion ever recieved a 3v motor. They were only offerred in the following combinations.
They only difference in the programming was the fact that that were named differently to differentiate which year went to what.
2004 Excursion with 2004 engine: VXBC
2005 Excursion with 2005 engine: VXDA or VXDB
I believe they started with the vsm in 2002, I know my 2002 6.8 has one. Also the digital odometer and some other electronic upgrades. I had an issue with my vsm and the cause was a broken communication wire between it and the rest of the vehicle modules, gauge cluster (which I believe acts as the gem) being the primary one. Not sure if that wiring is can bus or not.
Correct and despite trucks built around June of 2005 having a 2005 engine, they still ran programming based off of a 2004 strategy. I.e. no CAN Bus
They did indeed start with VSM for the 2002 MY. It was a nice upgrade over the 99-2001 setup. The cluster is the focal point for alot of the vehicle's features on some Ford vehicles, so when it goes out, alot of things start to not work.
I did an oil change and took off the sode moulding off my truck. got the rock deflectors on order should be here next week
