What did you do to the X today?
  #49141
Old 12-01-2018, 08:53 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
Skip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputation
Talking
Originally Posted by Snowseeker View Post
Earthquake in Anchorage. Alaska friends ok?
geez a little earthquake and you guys all go crazy, nice you guys think of us tho. we did lose a coffee mug that fell off the fridge other then that nothing bad happened. i think it was worse for people in the lower 48 then it was for us,
  #49142
Old 12-01-2018, 08:54 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
Talking
Originally Posted by Toreador_Diesel View Post
I called Russell earlier, he and his family are OK
Not sure about Skip though
haha! ya my wife was telling me somone left a message today! i didnt call back busy fighting the crowds at the store getting some junkfood.i was almost out of donuts!
  #49143
Old 12-01-2018, 08:56 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
Originally Posted by Flyboy1100 View Post
my new arms easily have double the spring force of my old ones, but i will keep this in mind if i need to do this again.
can you get the springs thru ford? i hate to use some sceen door springs from the hardwarestore.
  #49144
Old 12-01-2018, 09:01 PM
Flyboy1100
Flyboy1100 is offline
Flyboy1100 is a name known to allFlyboy1100 is a name known to allFlyboy1100 is a name known to allFlyboy1100 is a name known to allFlyboy1100 is a name known to allFlyboy1100 is a name known to all
not from the parts listing.
My old ones were pretty bad lookimg anyway, for now iím happy with the change
  #49145
Old 12-03-2018, 10:07 PM
unleashd's Avatar
unleashd
unleashd is offline
unleashd has much to be proud ofunleashd has much to be proud ofunleashd has much to be proud ofunleashd has much to be proud ofunleashd has much to be proud ofunleashd has much to be proud ofunleashd has much to be proud ofunleashd has much to be proud of
After giving up on finding a set of HD 18's, I scored a set of almost new 20's along with lug nuts and hub caps for a very very good price. Now starts the search for tires and spacers. This pattern is my all time favorite design of the OEM wheels made by Ford.
  #49146
Old 12-03-2018, 10:26 PM
seijirou
seijirou is offline
seijirou has much to be proud ofseijirou has much to be proud ofseijirou has much to be proud ofseijirou has much to be proud ofseijirou has much to be proud ofseijirou has much to be proud ofseijirou has much to be proud ofseijirou has much to be proud of
I'm with you on that. If I were to do it again I would go with 2" BORA spacers. I also replaced all the studs in my spacers with OEM studs.
  #49147
Old 12-03-2018, 10:39 PM
unleashd's Avatar
unleashd
unleashd is offline
Donald, Did you have to do the spring swap to gain more clearance for these wheels? What size tires did you go to?
  #49148
Old 12-03-2018, 10:47 PM
seijirou
seijirou is offline
I did change the springs but it was because my fronts were bottoming out constantly. I expect it would fit fine at a stock height with healthy springs. My tires are 275/65-20 Nitto G2
  #49149
Old 12-04-2018, 06:09 AM
unleashd's Avatar
unleashd
unleashd is offline
What spacers do you currently run on them? I can't afford Fred's adapters.
  #49150
Old 12-04-2018, 06:27 PM
seijirou
seijirou is offline
EDIT: Sorry Prakash I had this sitting in draft all day and never hit post apparently.
I'll give you 2 answers. BORA are the ones I would recommend.
Amazon Amazon
SDT are the ones I'm running. https://streetdirttrack.com/collecti...pacer-set-of-4
I recommend BORA because I've since learned that they just go right on front and rear no problems.
With the SDT the front went on fine but I had to do clearancing on the rear.
Also with the SDT the studs were just too short so I had to replace them. I never heard that about the BORA. Truth be told I would probably change them anyway because I like the long factory ones but I'd say use your best judgement. You can always fit them to the wheel before installing them on the truck to check.
  #49151
Old 12-04-2018, 07:27 PM
DidieX
DidieX is offline
DidieX is a name known to allDidieX is a name known to allDidieX is a name known to allDidieX is a name known to allDidieX is a name known to allDidieX is a name known to all
Originally Posted by DidieX View Post
Anyone know how long the warranty is on the 1aauto tow mirrors? I see the newer ones listed now have a limited lifetime warranty but the one I bought is no longer listed. The power fold motor seems to be going out on my driver's side mirror.
i thought for features not originally available they didn't warranty anything.
To follow up, I emailed 1Aauto on Friday and received a new set today. Need to send back the old ones to keep the warranty going as per the rep. I gotta say, that's pretty good warranty support.
  #49152
Old 12-04-2018, 07:32 PM
Nicmike's Avatar
Nicmike
Nicmike is offline
Veteran/Sheepdog
Nicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputation
Donald, are you frozen yet?
  #49153
Old 12-04-2018, 09:04 PM
Flyboy1100
thats good o know since those mirrors are still on my todo someday list
  #49154
Old 12-05-2018, 07:19 AM
DidieX
DidieX is offline
Based on this experience, I would say if you're going to do the upgrade then go with 1Aauto instead of eBay or Amazon. They may be similar quality but for the little you will save and end up without a warranty, it's better just to go with 1Aauto. And no, they didn't pay me to say that, just my personal opinion.
  #49155
Old 12-05-2018, 07:42 AM
seijirou
seijirou is offline
Yes I am. Stop laughing at me.
Quick Reply: What did you do to the X today?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
