What did you do to the X today?
Stewart
I read that and my mind couldn't help but picture your Ex pulling your trailer doing 200 miles around https://www.charlottemotorspeedway.com/
Stewart
Stewart
Installed new +battery cables and passenger side ground cable. Finally got the last driver's side valve cover bolt snugged down (you all know which one I mean). High-flow banjo bolts done, and no fuel in my armpit - I had the passenger's inner fender off, so I was able to access through there. Bellowed up-pipes installed and snugged down at the collector, still loose at the manifold. Maybe time left in the day to get the turbo pedestal installed and the waste gate set up on the turbo, possibly finish up the wiring harness re-do...
Ordered an idler pulley, headlights, front turn signals, taillights, and the actuator for the inop rear air floor/roof door.
Mine was doing the same thing and it turned out to be a bad fan clutch. I bought a cheap one off Amazon which was a mistake because it now never unlocks so I'll be buying another better quality unit. Point is, as soon as I replaced the fan clutch, all my overheating problems went away. I was hitting 230° pulling Fort Mountain with my camper in tow before. After I replaced the clutch, it was running right at 200° when I topped the same mountain. Just a thought...
^ Let it sit overnight, pop the hood and spin the fan. Wear gloves, sometimes the fan blades are sharp! It should be stiff to rotate since the fluid is cold. If it free wheels, it’s bad. Plus your idle ac vent temps will be warmer since it’s not pulling as much air through the rad and increased water temp
Hi guys, I'm in the middle of cleaning the engine bay but I had a quick question. There is some dirt under the engine bay fuse panel cover on some of the fuses and I was wondering if its safe to spray wd40 specialist electrical contact cleaner on those to clean it while the battery is still connected. It says its safe for all plastics and leaves no residue but I was concerned about the battery still being connected.
Thanks guys!
Thanks guys!
Now that you mention vent temps warmer, it is actually the opposite. My vent temps seem colder and the air temperature is low temperature at max heat setting when it is overheating. This is also a reason I'm leaning towards partially blocked radiator. But I will check everything.
Thanks for the help. I'll do that.
According to recent records and receipts from PO water pump and many hoses were replaced due to an overheating issue. Read something about hoses being replaced due to gunk. Also leads me to think radiator blockage. I was planning on starting my own thread once I run some more diagnostics.
Watched a Diesel Brothers on Hulu last night where they cut up a perfectly good, clean Excursion. The employee that "owned" it voluntarily sold it for $2500 for the project, it was his family car. You know he didn't own it because he sold it way too cheap and if he did he was just plain dumb.
I can't stand perfectly good vehicles being chopped like this!
https://www.discovery.com/tv-shows/d...flippin-diesel
Mine has a random misfire on cylinder 8 if it sits for 3 or 4 days, I think it's moisture related, it goes away after it warms up. I still have 2 spare denso/motorcrsft cops, got to swap one in one of these days.
And I noticed the front passenger side caliper seems to be locking up intermittently. From what I remember from the last brake job the caliper was in good shape. I think I need to do a proper flush/bleed of the entire brake system.
https://www.ford-trucks.com/forums/1...l#post12209418
and how old are your rubber lines? I had to replace all of mine. the rear were rusted internally and collapsing. that would lock pressure on the caliper and caused a dragging brake. About $30 later and the issue was fixed.
I'd also like to know. Guy I got them from told me they are dick Cepek but if they are, they must be pretty old and they don't look like they've been around the block that many times. Nothing on the Cepek site shows these wheels.
Finished taping up the wiring harness. Installed the turbo and connected the downpipe. Cleaned some ancillary engine parts (brackets and such).
Seems I need seven hands to install the collector to the back of the turbo, any magic to getting the collector to line up after installing bellowed up-pipes?
