What did you do to the X today? - Page 3221 - Ford Truck Enthusiasts Forums
Old 05-15-2018, 06:38 AM
Matt M, PA's Avatar
Matt M, PA
Matt M, PA is offline
Matt M, PA has a great reputation on FTE.Matt M, PA has a great reputation on FTE.Matt M, PA has a great reputation on FTE.Matt M, PA has a great reputation on FTE.
Originally Posted by jasoncw View Post
Here is someone else's write-up on it:
https://www.ford-trucks.com/forums/1...ock-parts.html
Thanks...I have seen that thread before. I was hoping for info on the actual switch shown...makes a nice install.
  #48302
Old 05-15-2018, 08:25 AM
SmackDaddy's Avatar
SmackDaddy
SmackDaddy is offline
Shade Tree Wrencher
SmackDaddy has a very good reputation on FTE.SmackDaddy has a very good reputation on FTE.SmackDaddy has a very good reputation on FTE.SmackDaddy has a very good reputation on FTE.
Originally Posted by carbon coupe View Post
I did mine a couple of years ago. Recently put new style seals in my front doors and did some investigating. The tubing I put in the old ones was basically dust. It added no increased fluffing or dampering of the cell it was in. Yes I bought surgical tubing, yes, I put it in the correct place..... not sure what happened. I feel weather and outside influences (salt) had a huge effect on this. In the long run, replacing the seals with the updated version is clearly the better choice. On top of the fact that getting this tubing in the seal was a total PIA (pain in ****), it is a very short term fix. I appreciate the thinking and effort that went into presenting the tutorial but in the end, its just a (short term) bandaid. Mind you, in other climates there may be no issue but I have confidence in the engineers that created the latest version of the seal and will be replacing the rears with the same OEM type upgrade.
When installing the new upgraded seals, if you go that route, put them on in a nominal state and see where the ends fall. If too long, trim, but make sure your corners are pushed on all the way. If too short, start over and put a little stretch in the seal as you go around the A/B flange. I put mine in the sun for a couple of hours first. Makes them hot but easier to pull.
What did you use to lubricate the tubing? Some lubricants will break down rubber, latex etc.
  #48303
Old 05-15-2018, 11:25 AM
Twitchyleprechaun's Avatar
Twitchyleprechaun
Twitchyleprechaun is offline
Not So Nice Leprechaun
Twitchyleprechaun has a superb reputationTwitchyleprechaun has a superb reputationTwitchyleprechaun has a superb reputationTwitchyleprechaun has a superb reputationTwitchyleprechaun has a superb reputationTwitchyleprechaun has a superb reputationTwitchyleprechaun has a superb reputationTwitchyleprechaun has a superb reputationTwitchyleprechaun has a superb reputationTwitchyleprechaun has a superb reputationTwitchyleprechaun has a superb reputation
So just for the hell of it; I am removing the comolete dash in the parts EX with the plans to clean it up, paint it, and put it into my EX. Basically going for the Eddie Bauer dash colors. Removing the dash may also let me get some sound deadening material on the firewall as well.
  #48304
Old 05-15-2018, 03:25 PM
Excurvelle's Avatar
Excurvelle
Excurvelle is offline
Excurvelle has a brilliant futureExcurvelle has a brilliant futureExcurvelle has a brilliant futureExcurvelle has a brilliant futureExcurvelle has a brilliant futureExcurvelle has a brilliant futureExcurvelle has a brilliant futureExcurvelle has a brilliant futureExcurvelle has a brilliant futureExcurvelle has a brilliant futureExcurvelle has a brilliant future
Heading to Cruisin OC tomorrow with the car hauler in tow. Looks like rain but a week off from work with the family is worth it. Just need to fuel the Ex, load up and hook up and we are heading for the Delmarva Peninsula.
  #48305
Old 05-16-2018, 05:43 AM
scooterfj62's Avatar
scooterfj62
scooterfj62 is offline
scooterfj62 is starting off with a positive reputation.
Originally Posted by Matt M, PA View Post
scooterfj52....I'd be glad to know more about your mirror switch. Looks great! I've been wanting to do this in my truck, but your solution puts this at the top of my list. What parts were used, etc?
Stock switch from I believe a Lincoln Navigator. Found it on flea bay. Will see if I can find a part number and edit post. Car stereo buddy of mine did the install.
  #48306
Old 05-16-2018, 08:51 PM
carbon coupe's Avatar
carbon coupe
carbon coupe is offline
carbon coupe has a brilliant futurecarbon coupe has a brilliant futurecarbon coupe has a brilliant futurecarbon coupe has a brilliant futurecarbon coupe has a brilliant futurecarbon coupe has a brilliant futurecarbon coupe has a brilliant futurecarbon coupe has a brilliant futurecarbon coupe has a brilliant futurecarbon coupe has a brilliant futurecarbon coupe has a brilliant future
WD40.....maybe..... I think thats what was in the tut. If not, that could have been the culprit. Good call. More research needed.
  #48307
Old 05-17-2018, 12:20 AM
brannman
brannman is offline
brannman is starting off with a positive reputation.
I washed it. Turns out I have a white Ex! Who knew....
  #48308
Old 05-17-2018, 01:52 PM
96firephoenix
96firephoenix is online now
96firephoenix is gaining momentum as a positive member of FTE.
got an owners manual off of ebay. practically new condition.
  #48309
Old 05-17-2018, 07:21 PM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)
Tylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputation
Looking at a cross country move from CT to Seattle. Hard decision, but traded our 2015 Tahoe and Excursion in. For a 2017 Suburban. Sad to see her go, but it was best for us IMO.
My fleet. I'll finagle into a Superduty or Excursion again...lol
  #48310
Old 05-17-2018, 08:02 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
Skip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputation
sururban, yuk-o!!!!!
  #48311
Old 05-17-2018, 10:15 PM
EXSwap's Avatar
EXSwap
EXSwap is offline
EXSwap has a great reputation on FTE.EXSwap has a great reputation on FTE.EXSwap has a great reputation on FTE.EXSwap has a great reputation on FTE.EXSwap has a great reputation on FTE.
The good news is, Seattle is a pretty cool town. Youíll have to take a day and hit the Pike Street market and see the strawberry man. He sells dried strawberries by the pound that are amazing. Itís hard to put them down.
Good luck! Hope to see you back here with an X!
  #48312
Old 05-18-2018, 04:16 AM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)
I lived up there for 6yrs in early 2000's while stationed at the Navy base in Silverdale. We loved watching the Pike Place fish tossers. And there was a booth with dried apple chips. Good stuff
  #48313
Old 05-19-2018, 06:34 PM
01__Excursion's Avatar
01__Excursion
01__Excursion is offline
01__Excursion has a very good reputation on FTE.01__Excursion has a very good reputation on FTE.01__Excursion has a very good reputation on FTE.01__Excursion has a very good reputation on FTE.
Do you mind my asking what the trade-in amount was that you received on the X?
  #48314
Old 05-19-2018, 06:41 PM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)
rusted fist size holes rear rockers, and fist size holes on both inner rockers, interior was pretty much perfect (no holes, 100% there, every gadget worked). no other rust, 94000 miles, 2000 V-10 XLT
they gave me $3500 trade.
  #48315
Old 05-20-2018, 06:07 PM
ExxWhy's Avatar
ExxWhy
ExxWhy is offline
ExxWhy has a superb reputationExxWhy has a superb reputationExxWhy has a superb reputationExxWhy has a superb reputationExxWhy has a superb reputationExxWhy has a superb reputationExxWhy has a superb reputationExxWhy has a superb reputationExxWhy has a superb reputationExxWhy has a superb reputationExxWhy has a superb reputation
Nice fleet, I'm sure the burb is quite luxurious. Still allowed to hang out here.
F350JOHN
246
12-24-2017 05:15 PM
propellerhead
15
04-25-2017 12:28 PM
86F150302
26
12-30-2016 08:25 PM
Snowseeker
55
06-25-2016 09:10 PM
Raleigh1
1978 - 1996 Big Bronco
682
03-18-2016 01:29 PM
Quick Reply: What did you do to the X today?
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
