What did you do to the X today?
  #47986
Old 04-03-2018, 01:48 PM
WE3ZS's Avatar
WE3ZS
WE3ZS is online now
World Famous Mod
WE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputation
The early EXs came with receiver hitches that were rated at 1k tongue weight and 10k trailer weight (with WD). Larter models have same exact hitches but with larger hitch to frame bolts and are rated at 1250 tongue and 12,500 trailer weight (WD). I replaced my hitch with a Torklift SuperHitch 20K that is rated at 2000 tongue and 20,000 trailer with WD, my 11k+ TT has a very heavy 1800+ lb tongue weight.
  #47987
Old 04-03-2018, 02:22 PM
Oldguyfl's Avatar
Oldguyfl
Oldguyfl is offline
Oldguyfl has a brilliant futureOldguyfl has a brilliant futureOldguyfl has a brilliant futureOldguyfl has a brilliant futureOldguyfl has a brilliant futureOldguyfl has a brilliant futureOldguyfl has a brilliant futureOldguyfl has a brilliant futureOldguyfl has a brilliant futureOldguyfl has a brilliant futureOldguyfl has a brilliant future
Just a bolt upgrade to get to the higher hitch numbers, right Tom?
  #47988
Old 04-03-2018, 02:23 PM
Flyboy1100
Flyboy1100 is online now
Flyboy1100 is a name known to allFlyboy1100 is a name known to allFlyboy1100 is a name known to allFlyboy1100 is a name known to allFlyboy1100 is a name known to allFlyboy1100 is a name known to all
thanks! If i start towing heavy with it i will look into that.
  #47989
Old 04-03-2018, 02:57 PM
WE3ZS's Avatar
WE3ZS
WE3ZS is online now
World Famous Mod
Yes, just an upgraded to the larger, stronger bolts will give you the higher towing ratings, the hitches themselves and all year EX frames are all identical. Your Ford dealer should have the new bolt set, the earlier smaller bolts are no longer available if I recall correctly.
  #47990
Old 04-03-2018, 03:03 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
Skip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputation
thats some good info might have to get me some new bolts too
  #47991
Old 04-03-2018, 05:43 PM
ArmyLifer
ArmyLifer is online now
ArmyLifer is a splendid one to beholdArmyLifer is a splendid one to beholdArmyLifer is a splendid one to beholdArmyLifer is a splendid one to beholdArmyLifer is a splendid one to beholdArmyLifer is a splendid one to behold
Anyone have part numbers for the stronger bolts?
  #47992
Old 04-03-2018, 05:52 PM
RobRoss's Avatar
RobRoss
RobRoss is online now
RobRoss has much to be proud ofRobRoss has much to be proud ofRobRoss has much to be proud ofRobRoss has much to be proud ofRobRoss has much to be proud ofRobRoss has much to be proud ofRobRoss has much to be proud ofRobRoss has much to be proud ofRobRoss has much to be proud ofRobRoss has much to be proud of
Not bolts but rivets. Protocol for replacing rivets is to go up one size if being replaced with a threaded fastener(s).
  #47993
Old 04-03-2018, 06:07 PM
Nicmike's Avatar
Nicmike
Nicmike is online now
Veteran/Sheepdog
Nicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputation
Rob, what are these rivets that you write about above?
  #47994
Old 04-03-2018, 06:34 PM
RobRoss's Avatar
RobRoss
The hitch is riveted on or at least so I thought I read.
  #47995
Old 04-03-2018, 06:36 PM
WE3ZS's Avatar
WE3ZS
WE3ZS is online now
World Famous Mod
Robb, the factory hitch to frame fasteners are all bolts, but two of them (one each side) has a round head like a rivet to make removing the federally mandated rear crash protection hitch harder to remove.
Here are mine still in place just before being removed for the hitch replacement, the second from right is the round head bolt with a nut welded to it. I added that nut back when I dropped the tank the first time for a fuel pump replacement to make it much easier to remove later, and it was.
Here is the original hitch (now under Greenscoobie's EX) and the factory bolts.
http://imgur.com/VEQKjAP
And a closer picture of the factory bolts with some of the factory applied blue thread locker still on them.
http://imgur.com/EbMpPvY
Here are the two round head bolts with the new nuts welded onto them to make them easier to remove.
​​​​​​​http://imgur.com/A59R7bg
  #47996
Old 04-03-2018, 06:45 PM
WE3ZS's Avatar
WE3ZS
WE3ZS is online now
World Famous Mod
My iPad and the latest forum update are not playing well together and I can't edit any of my prior posts, and I think I screwed up the links to three of the above pictures so I'll try again here.
  #47997
Old 04-03-2018, 07:38 PM
RobRoss's Avatar
RobRoss
Tom, thank you for the correction!
  #47998
Old 04-03-2018, 09:45 PM
Flyboy1100
do the new bolts look the same, just larger? is there a measurement or distinctive size difference?
  #47999
Old 04-03-2018, 09:51 PM
Flyboy1100
2 of my new to me King Ranch wheels cleaned up today. still need to sand the inner lip of one of these pair and completely clean all the crap off the other 2. will take a before/after tomorrow if i get to it.
plan is to just touch up the few spots of clear that are beginning to bubble on the face of each wheel and touch up any curb rash, and reclear the inner lips. otherwise going to leave them alone. would love to paint or preferrably powder coat them chamaleon because it would look awesome with my Dark Satin Green paint, but powder coat is just too much money since i have no way to bake an 18" wheel and shops around here want 165 per wheel. plus they are in pretty decent shape so don't really want to destroy factory finish. need to find something to fill in corrosion pitting before clear though
btw: subaru wheel pictured was painted/cleared by me 50k ago, only seen winter use and needs to be redone, again powder coat not much of an option but they are only 16's so could fit in a kitchen oven (garage oven? just need to find a cheap enough one...)
  #48000
Old 04-03-2018, 11:13 PM
travs66's Avatar
travs66
travs66 is offline
travs66 has a very good reputation on FTE.travs66 has a very good reputation on FTE.travs66 has a very good reputation on FTE.
About a week ago, maybe 2, I started having this weird noise coming from under the X. I couldn't figure out what it was nor where it was coming from. The noise would be there in the afternoon on the way to work but gone in the morning or there on a trip in the morning taking the kids to school and then would be gone again. Needless to say it was driving me bonkers!
Tonight I decided to take the truck to the street outside our neighborhood. My driveway is too steep to do what I planned and the HOA would pitch a fit anyway
I jacked up the rear and put it on stands and blocked the front tires. I rotated the rear tires but could not hear the noise. I checked the driveshaft and the u-joints were just fine. I put my daughter in the driver's seat and had her crank it up and put it in drive. I had her rev to about 1500 rpm and I walked from the driver's side to the back to the passenger side and nothing out of the ordinary. More
I got back to the house and decided that it must me isolated to the front wheels. I started with the driver's side and this is what I found...
Size:  1.76 MBName:  photo31.jpg
I said to myself "self you have a small issue, that is not quite what the seals and bearings should look like!" After a trip to the parts store I started the reassembly and once I had the bearing assembly back in I realized I forgot the backing plate so back out comes the bearing assembly and on goes the plate. I get it all torqued down and then looked around and realized I forgot this...
You guessed it, bearing assembly was removed...again. Got the thrust washer in and the rest of the assembly went fairly smooth.
Needless to say I'm now sitting in my driveway enjoying a cigar and laughing at myself for being such an idiot
Ah the joys of working on your own rig.
Quick Reply: What did you do to the X today?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
