What did you do to the X today?
on
Yes load range E 18" Toyo Open Country A/T, 2 ish year olds under 10k miles @ cold 80 PSI.
The rear weight is under the tires capacity by several hundred pounds at the last scale of 5800 lbs on the rear axle.
These tires replaced similarly rated BFG T/A KO tires that failed similarly but catastrophically were as the Toyos never lost air just developed a vibration that I could feel. That's 4 rear tires in 4 years of RV ownership. The BFG's (my favorite tire ever a that moment) cost me over $7000 in body damage...
We are looking at '18 F350 Lariat DRW 4x4 CC 6.7 trucks. Currently I spend a weekend or more pre-tripping for these longer RV camping trips and am just flat burned out from doing that and working on the truck on the side of the road. The whole Transmission ordeal didn't help either.
At this point I want to be able to enjoy the RV destination going to the mountains or the beaches without fear and anxiety of a 16 year old truck.
A Dually might be Overkill but I might end up putting a SXS in the bed and my dirt cycles in the TH garage so some extra payload and tires is welcome.
With weight bars engaged.
That is not bad at all.
I don't have a picture of my most recent ticket but my weights were:
Front Axle: 3,600
Rear Axle: 6,700
Trailer Axles: 12,000
So far, we have not lost a tire on the truck and have towed at least 30,000 miles over the past 3 years. I do wish I could get some more weight on the front axles but we have the largest bars available for our hitch.
on
I completely understand that one. I think I am overly cautious about my tires. They get rotated every 5k miles, no matter what. Of course I check my tire pressures before a big trip, but they also get check at 1k mile intervals when I check all my liquids as well as do a visual inspection around and under the truck.
Ex had been parked beside camper all winter, moved it out front to plow the back road and get the Ex in the sun for the week.
Pulled the Ex up to the front. Not much snow left, snowfall has been far below normal, so hoping to drive to Grand Junction Thursday to take family to train station. Will be a good long hiway drive since it arrived in Dec.
siblings !
Misky, I can't wait to see your 4x4 conversion under way. It's going to be awesome!
i have not driven my Ex in a while. The roads are nasty and I just can't bring myself to get it dirty as crazy as tha sounds. Now with my Explorer back on the road I have almost enough daily drivers to pick something different every day of the week haha
Rudolph had a serious and rather profuse oil leak that was only getting worse, so he got some major love on St.Patty's day.
-New front crank seal
-New Harmonic Balancer and bolt
-Felpro Oil Cooler Seals
-New Radiator
-New Coolant temp Sender
-New Lower Radiator Hose
-6 Quarts of Mercon V
-4 Gallons of CJ-4 15w50
-1 Oil filter
-2 gallons of ELC
What I found:
-The harmonic balancer was well on it's way out. The rubber material wasn't too far from flinging itself out, a new, revised harmonic balancer fixed that.
-The oil cooler I paid to have redone back in 2011 since I was busy working was incorrectly sealed, causing a slow oil leak for the past 7 years. The shop had put the usual fat o-ring where it was supposed to go, but put two skinny o-rings on one side and not just one. Felpro kit solved that problem...this also explains why my oil filter was almost always covered in oil when it was oil change time.
-The front crank seal was torn and is why the oil leak I thought I fixed back in February only got worse. Further more, it seems that replacing the wear ring on the harmonic balancer, actually put it just out of place to where it would cause the leak. Nicmike had the tools for it, so we did the seal and harmonic balancer (replaced the wear ring on my old balancer) and it started as a slow leak and became the profuse one I had to deal with. So my advice to any of you regarding the wear ring on the harmonic balancer, just buy a new harmonic balancer. It also didn't help that I drove the crank seal in too far the first and second time I did this. After texting Clay, he confirmed that I went a little too far and I was able to knock the seal forward without destroying it. New harmonic balancer and crank seal = No more oil leaks.
-The radiator was in the early stages of cracking and since I was that deep in, I opted to warranty it out at the Irish. While I was letting the RTV set on the harmonic balancer key way, I got the radiator out and even though had the lines tilted up, they somehow managed to drain out 6 quarts of fluid which is enough for the trans not to be able to go into gear. 6 quarts of trans fluid later, it shifts like it should, but I still need to do a Mark Kovalski flush and filter change.
Bottom line: I now have a 7.3 that doesn't leak for the first time in 7 years. I'm happy, Rudolph is plenty happy now 17 years and 455K still running strong.
-New Radiator
-1 Oil filter
-2 gallons of ELC
What I found:
-New Radiator
-1 Oil filter
-2 gallons of ELC
What I found:
-New Radiator
-1 Oil filter
-2 gallons of ELC
What I found:
