What did you do to the X today?
Received 4,132 Likes
on
Picked up an almost new rear bumper. This will be installed after the 200K maintenance is completed. It came with mounting brackets, but no bolts. The parking sensors have been removed, which is fine since my EX doesn't have that. I plan to add LED pods inside them for reverse lighting.
The search for a front bumper is ongoing.....
Getting my modified B codes ready to install...finally.
Replaced the bushings in the spring eyes and the shackle with Energy poly bushings
Some of the tools I used to get the old bushings out.
Old bushings defeated.
It took me about an hour to do one spring. 50 minutes of that was on the darn shackle bushing. The spring eye bushings took about 5 minutes each.
Ordering 13.5 inch u-bolts and 3.5-4 inch spring pack bolts next
Sean, I don't have a press yet, so yeah I would love to have that thing. That said, it was the outer metal piece that took me a while to figure out. I pushed the center pin out half way, it wouldn't go farther with my C clamp, I drilled out the rubber on both side, the center pin then fell out with the rubber, and I just had to wrestle with the outer metal piece for a bit. Next spring is on deck for tomorrow, and I anticipate it taking MUCH less time than the one I did today. Ran out of time today before I had to report for work...
Received 5,155 Likes
on
