What did you do to the X today?
$532 and free shipping from Summit and a mail-in rebate of $50.00.
https://www.summitracing.com/parts/gib-gp125s
I'm going to use sealant, no gasket, and anti-seize on all the bolts that came with it due to restrictions of size between flanges and pipes.
Still removing the damn studs, not enough free time and still have 6 below the surface to go....
I wouldnt't do it, any leaks before the O2 sensors could be catastrophic. From permatex's website.
OEM specified. For high operating temperatures common in 4-cylinder, turbocharged or high-performance engines. The most advanced, high temp RTV silicone gasket available. Sensor-safe, low odor, noncorrosive. Superior adhesion. Three times more oil resistant than conventional silicones; eight times more flexible than cut gaskets. Temperature range -65°F to 700°F (-54°C to 371°C) intermittent; resists auto and shop fluids and vibration.
At max power you will be 1300 F give or take depending on how long you're into the throttle.
I wouldn't do it, any leaks before the O2 sensors could be catastrophic. From permatex's website.
At max power, you will be 1300 F give or take depending on how long you're into the throttle.
Now for the good news-bad news, decided to remove the heads completely and found the gaskets were leaking oil on both sides, after considerable time spent already, I just ordered two new reman heads for $800 each and getting the list together on other items to be replaced while we're in there.
Post a pic of the hylomar when you get it. I've used other forms of it but not the one you mentioned.
Originally Posted by sddesigns
After doing some more research, you are absolutely right, I just ordered Hylomar Advanced Formulation after speaking with the CEO of the company. The bonding process occurs once heated up.
Originally Posted by Bently_Coop
Head gasket's were leaking? Turned into an expensive header job. Hate how these things snowball.
I kept wondering why you didn't opt for gaskets. You're way to far in NOT to use gaskets. When I had the exhaust manifolds off my 6.0 this past summer, I put some Felpro gaskets on once I tacked on the BD Diesel manifolds.
Just wait till you own a neglected 6.0....
Same here. But I didn't have the equipment to weld nuts and washers on. Mine is in the shop right now and they are trying to remove them. Not sure how it will end. little nervous on cost
