What did you do to the X today?
Follow your negative off the driver's side and it bolts to the frame. Bolt one end to that bolt and the other end to a threaded hole on the block. I could not find a threaded hole that was not buried so I bolted it to the bolt next to the oil dipstick. I have the same alternator and cables and installed mine two weeks ago. It works great!
Sorry you missed the instructions, but glad you got it sorted! One thing I did notice is that you appear to have not installed the extra heatshrink that is used as an addtional layer of protection under the radiator core supports. This is hardly essential, but does help prevent chaffing due to the sharp edges under that.
Thanks for the business!
Not today, but recently, I put a zerk in the lower passenger side ball joint.
It's the one that started making noise so I figured since it wasn't loose, I'd try this first. It took a day or so for grease work work in but it's silent now. I'll do the drivers side soon. Not sure how much more life it'll have, but I hope I caught it before the knuckle completly wore out the cup.
Changed the oil the other day too. Oh, and the inline toilet paper trans filter. Not sure it had ever been done, and it was nasty. Had it sitting here for a year before I remembered.
Not very exciting, I know.
She still runs like a bat out of hell though!
double post mods please delete
Mods note:
*Poof*
This post has been deleted. You no longer see it, so everyone ignore it.
Mods note:
*Poof*
