What did you do to the X today?
Old 06-04-2016, 10:39 PM
Resto Guy's Avatar
Resto Guy
Resto Guy is offline
Originally Posted by Aaron_Jones
I took some tools back to the Auto Part Store that I didn't need and picked up a Stainless Steel Pipe Tip ($38.99).
Lenth 14"
Inlet Diameter: 3.75"
Outlet Diameter: 4.5"
Fits: 2.75" to 3.5" Pipes
Before:
After:
I bought the very same one for mine and it added a better sound. The same tip is also marketed under different names. The downside is the clamps will not stay tight. At least mine kept working loose. After losing mine a few weeks later I bought a Dynomax tip that I welded on.
  #42347
Old 06-05-2016, 06:18 AM
Skip1970's Avatar
Skip1970
Skip1970 is offline
Originally Posted by Country_Mouse
Took the Ex to see the Brady House. Yes, we're dorks.
wooah looking good, hubba hubba hubba!
  #42348
Old 06-05-2016, 07:01 AM
mecdac's Avatar
mecdac
mecdac is offline
You mean the TV sitcom with the gay father and the mother that had relations with her eldest child?
  #42349
Excurvelle's Avatar
Excurvelle
Excurvelle is offline
I would never have recognized it, looks a lot different than the way it looked on the show. We all like the Brady Bunch, my 11 year old has watched all of the episodes on You Tube and Netflix.
  #42350
Old 06-05-2016, 07:50 AM
Aaron_Jones's Avatar
Aaron_Jones
Aaron_Jones is offline
Thanks for the heads up. My pipe seems to have a incline going up toward the end. I noticed when putting it on it seemed to tighten all the way down to the end of the thread. So for it to also fit a 2 3/4 pipe I would have to say not likely. I will take it back off and use some loctite and see if I can keep it a little longer bro. It doesn´t change the sound at all for me, but probably because I pushed the tip so far onto the exhaust pipe. It is 14¨ but I may only have about 4¨- 6¨ hanging off the exhaust pipe. Thanks again for the heads up.
  #42351
Old 06-05-2016, 08:00 AM
Irish19614x4's Avatar
Irish19614x4
Irish19614x4 is offline
Nice looking Ex! What step rails or Nerf bars are those?
  #42352
Old 06-05-2016, 08:17 AM
Aaron_Jones
I got the mounting kit for the eX for
$82 on Amazon $82 on Amazon
And the bars are I got for
 $152 from Amazon but has gone up $100 sinse I purchased them $152 from Amazon but has gone up $100 sinse I purchased them
they are called Rampage Jeep 14190 Xtremeline 90" Stainless Steel Running Board
The good thing about these Rampage Bars is that the end pieces can be painted. I did not find this out till after the paint job had begun. I think it would have a nice personlized look of the end pieces were painted the same color as the truck.
  #42353
Old 06-05-2016, 09:36 AM
mjoyce's Avatar
mjoyce
mjoyce is offline
Did a full cooling system flush following the instructions from the srmastertech.
Evidently he passed away so his absolute badA$$ videos stopped. He was one of the good ones. Removing the block plugs didn't get the super powerful water shooting out of my engine during the part II portion of the video so I am wondering if my water pump is weak or just bad.
A couple of observations. Flushing the cooling system at home absolutely is terrible. pulling the block plugs I had to remove the starter on the passenger side. I took a bath several times. Hot water is super hot by the way. Running the engine to normal operating temp and running the heater all takes a ton of time. Buying 20 gallons of distilled water. The whole thing sux. I recommend buying some ribs and begin to smoke them then start the flush. It will give you something to do while the flush happens.
This isn't apple pie moonshine its the used old coolant. I wanted to see if I saw silicates or general junk in it.
replaced my original radiator hoses upper and lower along with the thermostat
only the ford stuff. I used vc9 to flush the system.
removed a ton of crap to work in the super tight 6.0 engine bay.
Just a picture of progress.
  #42354
Old 06-05-2016, 09:37 AM
Phillip123's Avatar
Phillip123
Phillip123 is offline
Did a quick wax. Not bad
  #42355
Old 06-05-2016, 10:06 AM
Snowseeker's Avatar
Snowseeker
Snowseeker is offline
Mine is covered in tree jiz.
  #42356
Old 06-05-2016, 10:11 AM
Aaron_Jones
Any Pics of the wax job? What wax did you use?
  #42357
Old 06-05-2016, 05:58 PM
Snowseeker's Avatar
Snowseeker
We are under a server thunderstorm warning. I heard "time to grill out!" The X is near by.
  #42358
Old 06-05-2016, 07:36 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
Evidently he passed away so his absolute badA$$ videos stopped. He was one of the good ones. [/I]
I'm not familiar with srmastertech, but I know DieselTechRon just passed away from a vehicle collision. Are you sure you aren't confusing the two?
Stewart
  #42359
Old 06-05-2016, 07:55 PM
Greenscobie86's Avatar
Greenscobie86
Greenscobie86 is offline
Nice! I've got that same grill hah.
  #42360
Old 06-05-2016, 08:32 PM
USCG_PA's Avatar
USCG_PA
USCG_PA is offline
The angle and lighting of this image makes your Ex look like it does not have the back windows... Is yours a special delivery van edition?
Quick Reply: What did you do to the X today?
