What did you do to the X today?
  #41701
Old 04-20-2016, 08:43 PM
mjoyce's Avatar
mjoyce
mjoyce is offline
mjoyce is gaining momentum as a positive member of FTE.
Originally Posted by FICMrepair.com View Post
Thanks for the business! Looking good!!
A few suggestions:
1. The zip ties included the kit are intended to be used to hold both the positive and ground wires up off of the things that can get hot. We suggest using the zip ties to hold the wires up to the plastic wiring harness carrier that Ford provided.
2. Ideally, the routing of the cabling leaving the alternator should go directly to the driver side (running parallel to the bumper) for several inches before going back to the firewall to avoid any chance of the wiring coming into contact with the hot side CAC tube (which gets hot enough to melt insulation).
3. Many have achieved a space between the CAC tube and the back of the alternator by rotating the CAC tube slightly. All you need is a little bit of clearance.
Hope this helps! If ever you need anything else for your 6.0, please don't hesitate! If you can get it from the OEM or you can get it in the aftermarket, you can get it from us - just for less of your hard-earned money!
First of all many thanks for responding to my post. Awesome customer service!
Ok I will implement all of your suggestions. Like I said I am going to try and adjust the cac again. It seems like it would be super easy but I am struggling with it. Ill post the after pics when I have completed the changes.
  #41702
Old 04-20-2016, 09:48 PM
ExxWhy's Avatar
ExxWhy
ExxWhy is offline
ExxWhy has a superb reputationExxWhy has a superb reputationExxWhy has a superb reputationExxWhy has a superb reputationExxWhy has a superb reputationExxWhy has a superb reputationExxWhy has a superb reputationExxWhy has a superb reputationExxWhy has a superb reputationExxWhy has a superb reputationExxWhy has a superb reputation
A new box has arrived.
  #41703
Old 04-20-2016, 09:54 PM
USCG_PA's Avatar
USCG_PA
USCG_PA is offline
USCG_PA has a superb reputationUSCG_PA has a superb reputationUSCG_PA has a superb reputationUSCG_PA has a superb reputationUSCG_PA has a superb reputationUSCG_PA has a superb reputationUSCG_PA has a superb reputationUSCG_PA has a superb reputationUSCG_PA has a superb reputationUSCG_PA has a superb reputationUSCG_PA has a superb reputation
So, I was going through a drive through, a place whose service was so bad, that I left without ordering and went to a competitor... But that is a story for another time. But while waiting to be able to get out of the drive thru line, I was behind a competitor's "large" SUV. Funny, it didn't seem all that large.
...and pay no head to my deltas, I am running Bullet Proof Diesel's remote oil filter and cold weather cooler system, so my temps are almost never the same, unless I am really on it and cruising in the warm weather.
  #41704
Old 04-20-2016, 10:11 PM
Irish19614x4's Avatar
Irish19614x4
Irish19614x4 is offline
Irish19614x4 has a great reputation on FTE.Irish19614x4 has a great reputation on FTE.Irish19614x4 has a great reputation on FTE.Irish19614x4 has a great reputation on FTE.Irish19614x4 has a great reputation on FTE.
Originally Posted by Country_Mouse View Post
It is 14 years old....
What is forum 19?
My DH been doing some research. Said looks like an $85 part plus fluids and bleeding lines. Said possibly air in fluid?
Been driving it all day except when I had to go on fwy without a recurrence.
Just bleed the breaks to release the air. I'm thinking air as well but then I would be searching for source of air leak. Which might be Master Cylinder or brake reservoir cover gasket is bad and not sealing or wasn't sealed and now your fixed the issue when checking your fluid earlier.
  #41705
Old 04-20-2016, 10:13 PM
gots_a_sol's Avatar
gots_a_sol
gots_a_sol is offline
gots_a_sol has a brilliant futuregots_a_sol has a brilliant futuregots_a_sol has a brilliant futuregots_a_sol has a brilliant futuregots_a_sol has a brilliant futuregots_a_sol has a brilliant futuregots_a_sol has a brilliant futuregots_a_sol has a brilliant futuregots_a_sol has a brilliant futuregots_a_sol has a brilliant futuregots_a_sol has a brilliant future
Previous generation of truck, doesn't count
  #41706
Old 04-20-2016, 10:14 PM
Irish19614x4
It's not your deltas I'm worried about I'm concerned about that Edge programmer. I heard bad things about them but I have also heard good things so I suppose it might balance itself out. The Edge CTS monitor is great but for tuning I would go with SCT but that's just experience and reviews I have read.
I had same Edge on my 2003 Ex and within a month my HPOP and oil cooler went bad rupturing and puking coolant as in oil in coolant. I personally don't think it was the programmer though I blame it on bad luck. Anyways good luck!
  #41707
Old 04-20-2016, 10:16 PM
Irish19614x4
Jealous! What did it run you?
  #41708
Old 04-20-2016, 10:19 PM
USCG_PA's Avatar
USCG_PA
USCG_PA is offline
Don't worry, that is not and Edge programmer anymore. It has been reworked and is now a FICM programmer. I uploaded one of four FICM programs from it, and now just use it to monitor things.
For my main program, I am currently running a stock SCT street tune.
  #41709
Old 04-20-2016, 10:21 PM
ExxWhy's Avatar
ExxWhy
ExxWhy is offline
What is forum 19?
Any possibility it was the ABS going off?
  #41710
Old 04-20-2016, 10:24 PM
ExxWhy's Avatar
ExxWhy
ExxWhy is offline
  #41711
Old 04-20-2016, 10:36 PM
IMASAP's Avatar
IMASAP
IMASAP is offline
IMASAP has a spectacular reputation.IMASAP has a spectacular reputation.IMASAP has a spectacular reputation.IMASAP has a spectacular reputation.IMASAP has a spectacular reputation.IMASAP has a spectacular reputation.IMASAP has a spectacular reputation.IMASAP has a spectacular reputation.IMASAP has a spectacular reputation.IMASAP has a spectacular reputation.IMASAP has a spectacular reputation.
In case you weren't aware, there is a $25 mail in rebate on them.
https://www.airliftcompany.com/support/rebates/
When I did mine a year ago the rebate was $50. I also got mine on Amazon.
  #41712
Old 04-20-2016, 10:44 PM
Country_Mouse's Avatar
Country_Mouse
Country_Mouse is offline
Country_Mouse has much to be proud ofCountry_Mouse has much to be proud ofCountry_Mouse has much to be proud ofCountry_Mouse has much to be proud ofCountry_Mouse has much to be proud ofCountry_Mouse has much to be proud ofCountry_Mouse has much to be proud ofCountry_Mouse has much to be proud of
I really don't think so. I've felt that before and it has never made me almost poop my pants, lol.
But since it hasn't happened again all day I start doubting myself. Not sure if we should wait and see if it happens again or take it in...
  #41713
Old 04-20-2016, 11:00 PM
wpnaes's Avatar
wpnaes
wpnaes is offline
wpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputation
What is forum 19?
General Non-automotive forum. https://www.ford-trucks.com/forums/forum19/
  #41714
Old 04-20-2016, 11:02 PM
AlaskanEx's Avatar
AlaskanEx
AlaskanEx is offline
Bleed Ford Blue
AlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputation
ugh, the Olds has a nasty rear main seal leak. Debating on nursing it along all summer and put it in the shop over the winter, or try and get it done now before summer kicks off and I'll want the convertible all the time...hmm decisions.
The Ex sat all pretty and washed up in the driveway again today.
  #41715
Old 04-20-2016, 11:18 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
Skip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputation
hard to keep up with all the maintance on old crap
Quick Reply: What did you do to the X today?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
