What did you do to the X today?
Today, I got around to doing coils and plugs on the Ex. When we were coming home from the last camping trip, the Ex started bucking at light throttle openings. My original thought was possibly a throttle position sensor, since it only happens at tip in to 1/4 throttle. I hooked up to torque on my phone, and ran the throttle from closed to WOT and saw no jumps in the TPS readings. Just for fun, I checked for codes even though I didn't have a CEL, and sure enough, P0305. So I went ahead and ordered 10 coils off Amazon. I know I'll catch some flak for it, but I didn't go Motorcraft, but the cheaper lifetime warranty ones on there. I really can't afford to drop $600 on all new genuine ones. I also picked up 10 Motorcraft plugs, and anti seize, dielectric grease and that nifty magnetic socket.
To be honest, I was kind of dreading doing this, all the horror stories freaked me out. I started on it at around 11:30 and just got everything buttoned up about 20 minutes ago, including one trip to the parts store to get a magnetic pick up tool, since one of the coil bolts decided to take a leap in to the valley. Also the number 7 coil boot decided to sieze to the porcelain of the plug, leading to another freak out, since the spark plug socket wouldn't go over the head. Fortunately, a deep well 5/8 just fit, and I was able to get it out.
Here's what I pulled out laid out in order as if you're looking under the hood.
All the plugs were seriously over gapped, although the color on all of them look ok. The truck looks like it had a major service done, based on a sticker under the hood, at 92,000 miles. I'm assuming the plugs have been in for 100k since the truck now has just over 192k. Three coils are aftermarket, the other 7 are factory, and still working other then #5. I'll be keeping a couple of the good ones in the truck as spares, after I put new boots on them. Overall though, it's really not that bad of a job, I did pull the intake tube, as well as the evap port and PCV valve for additional clearance, and that really made all the difference. I'm definitely using a 50k interval for plug replacement in the future.
Believe me...... I was thinking about you the whole time. It honestly looks great.... way better than the plain old wax I used last time. I'm a little surprised how well it hides all the fine scratches, especially on the barn doors where your fingers touch opening and closing the back.
In all honesty, you're probably right, and in six months I'll probably be complaining about failed coils, but I'm hoping in six months my work puts me back at my old rate of pay, and then I can stomach paying for OE coils. But right now, factory coils aren't in the cards after dropping 6k on the truck and another 1k+ on maintenance repairs.
Two reasons why I didn't just do the one. First it was going to cost almost as much for new boots, as the coils cost, so why not swap the coils with the boots. Secondly, the coils have almost 200k on them, so I view them as questionable.
I think the oem's come w a boot.
Hope you used a torque wrench on the plugs.
I knew I was going to get flak, here's the breakdown financially for me. My costs, were based on either the parts store where I work, or Amazon, I went with those two because I needed to make sure I got all the parts before my days off, and before I take the camper out next week.
If I went through work, 1 Motorcraft coil, 9 boots and 10 plugs would have run ~$150 with tax and my discount. Amazon was $56 for 10 generic coils and $34 for the plugs at work, again with tax and discount so $90 total.
In my experience (but not with the Excursion), I've had zero problems with aftermarket coils on a couple of different vehicles, including 50k on my Durango with Duralast coils. With that said, I've also noticed that OE parts are definitely a step up in reliability, and some vehicles are more picky about OE then others.
I was throwing a code for only cylinder 5. My thought process was given that it already had 3 coils replaced, and given that the cost was less to drop in all new, by going all new I give myself a baseline from which to start. I also have 9 known good spares if one fails I can send it in for replacement with no downtime.
Finally, I did make sure to torque them down using my inch pound torque wrench. I went with 200 inch pounds since recommendations run from 13 to 25 ft/lbs I shot for somewhere in the middle. I plan on re torquing them at my next oil change in 5k and listening closely for anything that sounds like an exhaust leak.
Let's not get started with exhaust leaks, that a whole other ball game....my passenger side manifold is hanging on for dear life....I'm sure the right sized NYC pothole will knock it off.
I hope to get it done myself one Sunday in the summer, there are some great write ups in the tech folder.
