What did you do to the X today?
Yesterday I put two new Deka batteries in. I got tired of jumping it if just started and moved without letting it run.
I just had no reserve.
They were Motorcraft 4.5 year old units.
I also got the 12k Engo winch installed and swapped the steel cable out for Synthetic.
This is all on the 05 EX.
I did an oil change and fuel filter change on the 05 cclb. It still runs like crap. Dropping it off the the diesel guru I'm the a.m.
A beautiful day to be working in the Ex! All wheels are off, the new stainless 4x4 vac lines are on, brakes are up next...
More pics later as the day progresses.
On a side note, my hubs were stuck on. Even though they were twist locked off, they were still engaged. If you are using your locking hubs, make sure they unlock after you are done! I thought mine were running free, but apparently not...
Finally fixed a thumping issue I have been chasing for years. It was the stabilizer bushings. I also unplugged my glow plug relay because I have had random dead battery issues. The jury is still out on the glow plug relay being the issue. Ford mechanics were unable to diag either issue in 3 different visits. SMH.
Stewart
Curious if anyone knows why the Ex's got the GPCM and the trucks got the relay....
It was only the non-California trucks that got the relay.
Emissions related is why, according to what I have read on the forums over the years, not based on info I personally have discovered.
Stewart
@Bently_Coop and I finished up the brakes. Not major issues, just a long day in the sun. So long that my head and neck got sunburned. The first of 2016 for me...
Here are some pics of the job before the sun went down...
Thanks for the help today Coop!
Lastly, my wheels FINALY shipped, they should be here in a week. According to the shipping company, it is a five piece shipment that weights a total of 551lbs.
551 POUNDS!!!!
Those are some heavy wheels and tires
551 POUNDS!!!!
I don't normally use Turtle Wax products, but I have had a "Jet Black" set for a while now and gave it a try today. I have to say that it did work to help hide the shallow scratches like the ones you get under your fuel filler where the cap sits. It is a two stage process with a liquid cleaner wax that is tinted black and a black tinted liquid carnauba wax. It also has a few bottles of black tinted detail spray to help with wax removal and detailing. It wipes off of chrome or glass or the other colors without leaving them black, unless you had a scratch in one, then it can be difficult to get it out. However for your hands... If you use this stuff....wear gloves.
These pics are before cleaning the running boards, wheels/tires and windows and right after the last coat of wax.
Bought some of this stuff the other day based on your review / pictures. If I'm not satisfied, I will be seeking a refund from you !
