In the "What do I do today" department, I bought half of the bolts I need for the diff cover install Lowes only had half of them so I have to go to the other one across town to get the other ones.
I just ordered the cover!!
What is the bolt size and length required for the new cover? i think i may go studs and nuts. or allen head bolts
Installed a GTP38R today. Adjusted the waste gate prior to install, it was very loose. All I can say is wow!! Totally different in the power band, sounds like a jet, no more surge, and smiles ear to ear.
Tractor Supply man, you can buy bolts in bulk there.
Got the hitch adjusted for the camper. Pickup makes the camper look small compared to the Ex.
I like your Puma, looks like you have the rear bunkhouse slide model. We looked at one of those but my son is over 6' tall now and could not fit on the bed, we opted for the FQSS with the large bed is the rear.
IMO Puma is a great basic camper, so far ours has been very enjoyable.
i took my steering arm nut off today to remove arm and install drop steering arm, man that nut was not no 400 ft lbs lbs like they claim it to be on at, it was less then 100 lbs torque i could tell as it was easier to remove then my lug nuts.
good thing i'm changing this out, as it was not as tight as it should have been.
It's a 32DBKS, so double bunk, kitchen slide. The beds on the one side in the back are longer than the ones on the slide side. But I didn't get the outside kitchen option. So there's 4 beds back there. I'm over 6 ft, and my little bro is even taller than me, the beds on the one side are ok for us, but can't stretch out completely unless you lay at a angle. Lol I really like the camper though. It's nice and works great for my kids. But they are little yet. 4 and 2. So they have plenty of room back there.
Greased my slip joint today. Messed around with hubs since they've been giving me trouble since I bought the Ex. Decided I was better off with new ones and ordered the Mile Markers. I have some popping noise when turning hard left not sure what it is but think it may be hub related.
