What did you do to the X today?
Jay, While you have the tank down now would be a good time to also remove the hitch to have better access to treat all areas back there as well as replace the round head hitch bolts with hex heads to make it easier to pull in the future if ever needed. I didn't have any proper sized hardware in my garage when I did my fuel pump so I just TIG welded a couple of big nuts to the round heads for the future. With the tank out of the way those round heads come out easy with a pipe wrench and a little heat to soften up the thread locker on them.
Andy, this project has your name written all over it...
2002 FORD EXCEXCURSION Limited 4X4 7.3 DIESEL
500K miles!
I had made a stand for it.... That didn't go so well. So I decided to use the ATV as it was the right height and I was about to light more fires if I didn't get some progress going on the frigging thing
The 60 Johnson started right up though
Hahahaha you guys are always good for a laugh whenever I log in.
1970's Johnson start up - YouTube
Sounds like that triple is running quite well on two cylinders.
Those little old 15 omc's are bulletproof! We have two of them we use quite often. Run like a top! Your not firing I take it? No spark or fuel?
I rebuilt a 60 not to long ago that I have been abusing ever since. In fact I get to beat on it tomorrow again for work.
The boss testing it out first time out.
Sounds like 2 cylinders? That's what it has sounded like since I bought it 3 years ago! Must be time for a spark plug change. I'm a noob with stuff like this.
Had the fuel system all apart on the 15 (9.9) and its definitely getting fuel. Will go get some new plugs tomorrow. This one has been sunk in 25 feet of salt water and it still ran when it was put away. Of course it required a rebuild during which it was upgraded to a 15 hp, but like you said I heard they are quite the engine. I hope it gets up and running again.
Never know when the 60hp Hydroelectric shift will give me trouble. I have to get the special gear oil at the border since getting it in Canada is a pipe dream.
Cheers,
Nate
PS - thanks for the advice on the 60
Cheers,
Nate
