Spent my day getting my front springs installed. Ex is back on 4 wheels but I still want to clean up and paint the frame a bit, gotta install my new KYB monomax shocks, torque everything to spec, (hopefully) adjust my steering wheel back straight, and put the front bumper back on.
Looks like the rear needs to come up about an inch to match the front, so I will give that some thought this week...
I believe its a tapered 3.5", but I want to say there are some 4.5" options as well.
Was it you that shared the lift block with the u-bolt holes incorporated in a different thread? That'd be my choice personally
Yes, the PMF blocks. They are nice but around $200. Another nice option (though its more of a want than need) is if you go with their upper spring plate (with larger holes) you can run their 3/4 inch U bolts. Yum.
I didn't get as much done as I had hoped this weekend, so I didn't dare drive to a nice level parking lot to take a few pics.
Although it was Friday, I did do some hauling with the EX.
Very cool! Whats the plans for it?
I changed the blown fuse for the dash power point/cig lighter. It has been blown since I bought the X like 5 years ago. I didn't know about it till I was on a trip with my brother a couple years ago and he went to plug something in and it didn't work.
Replaced my rear hub bearings. Ended up removing the parking brake on both sides and as you can see, the backing plate on the drivers side was removed and the remaining dist shield for the disc brake was trimmed. I really hate rust. Thats all i have to say about that.
Yessir.
from an 82 year old gentleman who bought it in 1955 and parked it in 1962.
Thx for the info A Rod
Originally Posted by 05MilMachine
I've got some 3d waterless wash and found its a recipe for swirl marks on black paint. No matter how wet I spray it or how soft the microfiber is. It only works on an already clean vehicle with a dust coating. I am considering my own water tank, but the water you can get here is salty, so that might not work out.
Sounds like a plan Bro, get the water then filter it I guess
