What did you do to the X today?
#3076
#3077
A little more work...
Installed the front receiver:
Fixed the body-to-battery-negative lead and the other chassis ground leads...PO did a huge hack job...
Before:
After:
Added the fuse to the Inverter B+ lead. I scratched my head for quite some time to figure out the best spot...decided to make a small mount and attach it to one of the three bolts on that "thing just inboard of the other thing that looks like a heater fan". Added maybe a foot to the cable...the bracket let me angle the fuse in line with an AC line. Not perfect but it's damn stable and the bends of the cable aren't too extreme:
Before:
After:
#3078
#3080
#3081
Pulled the driver seat, took off the skirt, arm rest, seat tracks and separated the top from the seat.
Pulled the seat bottom leather up and found one scorched section (but the wire insulation looked fine...WTF?). Cut a section out, soldered it and put some heat shrink over it. Didn't see any other obvious signs of shorting on the top side.
Looked at the upper section...no signs of shorting but you can see the "blue" from a few wires up high...not sure if this is just maybe the seat got wet, normal thinning of the heater pad or what.
I didn't remove any hog rings, so I couldn't visualize the entire seat heater.
Put it all back together, nothing.
REALLY want my heated seats to work!!! My wife's Jetta is spoiling me!
#3082
Common for the seat bottom heater grids to burn through. Seen that on many makes/models. You can take a meter and measure the upper and lower grids to see where the issue is. Haven't tried repairing the grid, usually just replace the bad one. Aftermarket ones are also available if Ford is too proud of the part. Put one in my wife's car for $75 complete.
#3083
#3085
#3086
#3087
I just did that same fix...it was on the top of the heating pad, thigh panel. That's the posting I put up above...it didn't work.
#3089
I didn't have a set of hogring pliers to replace the hogrings, so I didn't remove them to get at the heating element. It's stuck on with some kind of adhesive...was a little nervous to pull it off in case I damaged the heating element pad.
#3090
-Replaced #1 and #8 injectors with the replacements Full Force Diesel sent. Truck runs considerably better now, packing up the loaners I got from strokin'_tatsch please rep him if any of you see him.
-Found my top starter bolt loose, but bought another starter and replaced it anyhow. Here's why:
I took a chick at work out to lunch and when we went to leave, the X refused to start. (The starter was turning but it sounded like an RC car and wasn't enough to turn the motor.) I cycle the key two or three times trying and still nothing. I end up having a call a good buddy at work to come pick us up.
I borrow a company truck, go to Autozone, get a new starter, and head back to my truck. For whatever reason, I decided to try starting my truck again, when I do, it fires the first time!
I drive it back to work, go outside and remote start it at two seperate times and it starts no problem I go to an impromptu Christmas party after work and still, it starts no problem! Given the events presented before you, it brings me to this conclusion: My truck was either jealous of her, didn't like her altogether, or all of the above...
I decided not to take my chances and replace the starter.
Anyhow, truck is running good once more...now time for bed, I'm exhausted.
