2011 SD fuel economy...
I am interested in 2011, 250-350
Gas and diesel fuel economy
Wanted real world numbers towing,city,highway 55mph 80mph
You get the idea
Also likes and dislikes on the new truck
I just test drove a gas and diesel but could not drive far enough to get an good average.
Any info would be good
You get the idea
because you don't have enough posts (25), you can't use the FTE search function, but you can use google and look only on FTE..
there are a number threads in the 2011 6.7L Ford Diesel - Ford Truck Enthusiasts Forums section on diesel mileage..
Sam
Sam
F350 4X4 XLT crew cab, 6.2L gas, 3.73 gears. Daily driver, occasional towing.
I'm getting 15-16 mpg average cruising empty at 70 mph highway (about 1800 rpms.) Around town, depending on the right foot, about 12-14 mpg.
If I back the speed down to 60-65, I often approach 17 mpg, again highway and empty.
I don't have any good figures for towing loaded, really haven't kept track.
4500 miles on the truck so far and running great.
What I have seen from my 2011 6.2...
OK Dudes, here's the 411 on what I have seen so far on my machine. First, I took delivery of my 2011 F-250 SD on 18 June. It is in Lariat Super Cab FX4 trim, 6.2 gasser, 4.30 gears in the rear end. This is my 5th "truck", first Super Duty. All numbers are from actual miles driven and fuel uploaded. I always fill, refilling after passing the 1/4 point on the fuel gauge with 87 octane Shell gasoline. I have refueled the machine 4 times so far. I use the machine mostly local, have towed a 3,600 pound boat twice, (175 total towing miles ), towing only after the first 1,000 miles. When I ordered the truck I went with the 4.30's instead of the 3.73's because by my calculations, on the type of driving I would be using the machine for that the fuel mileage would not be that much different than with the 3.73's and the towing would be better. I do not drive for hours on limited access highways at a steady cruise speed. In that case the 3.73's would show there merit.
The average speed calculation comes from the engine run clock and the miles driven between fueling. I do not let the engine idle anymore than necessary and get underway within 30 -60 seconds from start up. I drive in a consistent manner and do not zoom away from stop lights, as I see my share of them. Besides, only a fool would drive like a cowboy in a 6,500+ curb weight machine.The average speed is an interesting number because it shows just how slow actual point to point driving in a non-limited access road environment is.
So far I am very impressed with the new 6.2 engine, it's very smooth and powerful. I don't think that the guys with the 3.73 final drive are doing much better with their average fuel mileage.
To Date: 1,632.9 miles on the clock
1st tank of fuel:
engine clock: 12:54:00
miles: 354.4
average speed: 27.47 m.p.h.
fuel milage: 12.51 m.p.g.
2nd tank of fuel:
engine clock: 13:08:50
miles: 348.2
average speed: 26.48 m.p.h.
fuel milage: 12.23 m.p.g.
3rd tank of fuel:
engine clock: 10:19:10
miles: 282.3
average speed: 27.35 m.p.h.
fuel milage: 12.16 m.p.g.
4th tank of fuel:
engine clock: 10:18:50
miles: 284.7
average speed: 27.59 m.p.h.
fuel milage: 12.39 m.p.g.
The numbers are derived from a spreadsheet I keep, my the trip computer looks pretty accurate, calling out 12.2 -12.5 miles per gallon. What final drive do you guys have in your machines? I have attached a photo of my machine below.
1st tank of fuel:
miles: 354.4
2nd tank of fuel:
miles: 348.2
3rd tank of fuel:
miles: 282.3
4th tank of fuel:
miles: 284.7
Hummmm... yes, well the machine has been over that speed, as stated that is the "average" speed. To calculate; take a tank of fuel, add up the miles to run thru that tank of fuel, then take the time off the clock to run those miles and do the math, you get the "average" speed. Remember, all the time spent at red lights and in traffic does take it's toll on "average" speed. If you do that calculation I am sure you will be surprised at the number you come up with for your "average" speed per tank of fuel.
Actually I've done this with my 6.0 for over 80,000 miles and it is right at 43 MPH...
Your MPG's will improve as your average speed increases...
F2502011
6.2L V8
17
06-03-2013 03:51 PM
jungleexplorer
05-08-2012 10:02 PM
Kuskoal
01-18-2008 07:39 PM
