Bronco II Ford Bronco II
key switch problems
Old Aug 5, 2010 | 06:08 PM
jbdII's Avatar
jbdII
key switch problems
Help, someone tried to rip off my BroncoII and fouled up the key switch to the point that normal removal does not work, can anyone suggest a way to remove the switch to replace it ? I'm having great difficulty any help would be appreciated
Old Aug 6, 2010 | 10:50 AM
87 XLT's Avatar
87 XLT
You need to replace the lock cylinder. As long as you can turn the key to run, it's a very simple job.
Remove the plastic column shroud & look for a hole in the under side of the column & turn the key to run. Shove a small screwdriver/drill bit/ whatever into the hole & shove the spring loaded pin out of the way. Pull the lock cylinder out.
Line up the new lock cylinder & shove it in until it clicks into position. Done deal.
Old Aug 6, 2010 | 03:46 PM
fl1a's Avatar
fl1a
Most of the auto parts chains have the cylinders at reasonable prices.
Old Aug 8, 2010 | 08:15 PM
jbdII's Avatar
jbdII
reply
thanks ,but the lock is jammed and won't turn on . now what?
Old Aug 9, 2010 | 12:14 AM
daughtersbronco's Avatar
daughtersbronco
Maybe talk to a locksmith, to see if he can pull the cylinder out. Otherwise, I think you have to pull the whole housing, but I've never had to do it. Sorry you're having this problem. People can be a$$e$.
Good luck.
Old Aug 10, 2010 | 12:57 PM
jbdII's Avatar
jbdII
they really can be, I think it must have been a real amature who tried to buboost my wheels ,I'm still working on it thanks.
Old Aug 10, 2010 | 02:50 PM
87 XLT's Avatar
87 XLT
I've heard of guys drilling the cylinder out. Not something that i'd want to try, but it's another option. I'd go daughtersbronco & call an automotive locksmith.
Old Aug 10, 2010 | 06:49 PM
fl1a's Avatar
fl1a
It is possible that the position of the wheel that is jamming the cylinder innards from turning to the run position. If the jerk was working the wheel it may be holding it from movement. Have you taken the covering off the steering column yet? You may be able to see if there is any movement on the actual ignition switch linkage.
Old Aug 10, 2010 | 06:52 PM
fl1a's Avatar
fl1a
One more thought, your insurance might fund a visit from the locksmith.
Old Aug 11, 2010 | 08:44 AM
jbdII's Avatar
jbdII
bronco
thanks , I never thought that the wheel might have been turned ,I'll go and check that right now . all the help is great this is a great site thanks again
threepiece
May 26, 2016 08:03 PM
killerfrogs
Apr 12, 2016 05:56 AM
killerfrogs
1997 - 2003 F150
Apr 11, 2016 06:29 PM
Chevota_72
Mar 29, 2016 08:42 PM
sawmaned
WTB - Parts & other
Aug 1, 2015 03:44 AM
