300,000 :)
just rolled over 300K yesterday
List of repairs to date:
1: 1 rebuilt transmission ( stripped clutch drum inner splines, transmission clutches where fine) $2300
2: 1 set of ball joints $680
3: 2 waterpumps $360
4: 2 fan clutches $480
5: 1 alternator $220
6: 3 sets of brakes $600
7: 1 ac compressor $300
8: 1 fuelbowl heater $64
9: 1 CPS $15
10: 1 power steering hose $23
11: 4 sets of tires $3200
12: 1 starter relay $38
13: 1 airfilter ( I had a K&N cone until 295K, switched to 6637 because I was tired of cleaning it) $40
14:45 oil changes $3600
15: 15 fuel filters $450
16: 2 batteries $240
17: switch to evans NPG+ $240
for a grand total of $12,850 spent on maintenance (off the top of my head) to get to 300K and she still runs and operated like new....thanks to FTE !!
<a href="http://s203.photobucket.com/albums/aa176/sclemenson/?action=view¤t=300Kpick.jpg" target="_blank"><img src="http://i203.photobucket.com/albums/aa176/sclemenson/300Kpick.jpg" border="0" alt="300K"></a>
9: 1 CPS $15
Contrats! These things sure rack up the miles don't they?
My truck is a slow-poke with only 253k miles. My list is similar.
Total Fuel: $45,206
43 oil changes: $2582
Scheduled Maintenance: $1276
4 sets of tires: $2692
Repairs: $7847
Repaired items:
117814 drive shaft center bearing
143781 overhaul transmission, tugger kit, cooler etc
144083 replace VSS and cup holder
187848 front hubs (both sides)
201200 rear pinion seal
236650 degas bottle cap
238217 UVCH retaining clip
241200 front sway bar bushings and spring tip isolators
243130 lower radiator hose and gooseneck o-ring
243130 ICP sensor
243453 replace #7 injector
244022 rebuild all injectors with new nozzles
250243 waterpump
250853 degas bottle cap (other one was wrong size..)
Oh yeah, 2 batteries every other year. I don't have good records because they get replaced under warranty, then pro-rated the second time. Then I start the process all over again....
Total Fuel: $45,206
Repairs: $7847
Repaired items:
243130 ICP sensor
250243 waterpump
