A little automotive trivia
#49
Paint? Prior to 1924, what vehicles were painted? None.
DuPont invented Duco enamel, the first car to use it was the 1924 Oldsmobile.
Prior years, all vehicles were varnished.
It cannot be a battery since early cars didn't have any. Automakers switched from 6 volt to 12 volt batteries in 1955/56.
Early bodies...even the frames were wood, so that rules out sheetmetal.
If the part can be taken from one vehicle of any year, then installed on another of a different make of any year, it cannot be anything specific.
#51
This part has not morphed, or changed since it's beginning, at least according to the radio host. I think it might have had some very minor improvements but if you placed an original part next to a brand new one you just picked up at the local parts store they would pretty much be identical. It did not change like a windshield, steering wheel or seat, all of these parts have changed with new technology and all are pretty much make and model specific, this part is used on all cars.
You don't need to know the year or make of the vehicle to buy it although the guys at the local chain parts store would probably need to know the year, make and engine to determine the part number and then tell you they could order it. At a good parts store the guy would just tell you "it's hanging on the rack over there".
#52
We have a weiner! Actually, I am referring to the inner valve core, the Shrader Valve, the little valve used in the valve stem of tubed and tubeless tires, among numberous other air applications.
I would assume there are some vehicles out there like the HUMMER, with the automatic inflation system, that don't use this valve but the vast majority of the new cars and trucks still use it. It was invented in 1891.
56panelford, I don't have any cookies for a prize, but just knowing that you had the answer should be reward enough!
#53
OK, that was disappointing... I was expecting something to do with the drive train. What confuses me is why would a parts man even bother to ask what it was to go on if they are all the same??? You must be talking about those kids they hire now that always ask if it has air conditioning when you just want to buy tail light bulb.
Later Man...
Later Man...
#54
Later Man...
Later Man...
The last time I went in to the Advance store I asked for a condenser for a '49 Ford truck. The guy punched the info into his computer and told me they didn't list a condenser for a '49 Ford truck. When I looked at the screen he had the window for the air conditioner system. I informed him I was looking for an ignition condenser, blank stare. Another person had to come over and punch a few more buttons and finally got the part number. Then they had to figure out where in the store they were. It was sort of like watching the Three Stooges.
For a laugh go into one of these chain stores and ask for a Shrader valve for front left wheel for a '56 DeSoto.
#55
When it comes to the chain outfits like AutoZone you are better off to go to their website, find what you want and then print it out and take it to the store. Then all they have to do is get it typed in right. However, I have actually seen them screw that up too. Ain't minimum wage wonderful???
Later Man...
#56
Unbelievable. And this was a question that was broadcasted out to the general masses on a radio show? In other words, the poor zombies out there who barely know how to pump gas heard this? And don't get me started about the poor kids behind those computers at parts stores. I agree with Dave. I look up the part number myself and then pray they can pull the same number off the shelf.
#57
Received 4,132 Likes
on
Actually if there is a reward of any kind it will have to go to my wife as that was the first thing that popped into her mind, I thought it over and figured it had to be the answer, she makes me proud.
#58
I just knew the so called answer would be wrong.
The Schrader valves used on inner tubes of early vehicles were huge, since the tires were huge.
So there's no way...none that a Shrader valve from say a 1908 Oldsmobile Limited w/44" tires will fit a 1909 Oldsmobile or anything newer.
I've seen auto related trivia questions like this before...usually the people asking them get the answers from Wiki Wiki.
Wiki Wiki is notorious for having false info. Their "automobile firsts" listings have more wrong info than right.
#59
I just thought it was an interesting bit of trivia.
