390 block?
352 not a 390.. darn...
I took two pictures of the block. As you can see, the front of the block says 352, so it must not be a 390. Also you can see no freeze plugs.
Ford Truck Enthusiasts Forums - travelerest's Album: 390 engine
If your on the level and can really buy that block for $200 it's a 427 sideoiler block. The King Daddy of the FE blocks. And the deal of the century if it's for real and the block isn't trashed. Even if the block is crap you can sell the maincaps and spacers for $250-300 and get your money back.
It MAY be/looks like a 427 block. Worth a lot more than a 390 block. If it is a sound 427 block, you should be able to resell it for enough to put a serious dent in a complete 390. Does the guy selling it say it's a "390" block?
Have the bores checked. A 4.05 is a 360/390/410, 4.13 is a 406/428, 4.23 is a 427. Only the 406 and 427 would have had the cross-bolted mains stock, and iirc very few 406s were done that way.
Date codes can be looked at too:
FE Quick Facts - Mustang & Fords Magazine
Ford Date Decoding id
http://www.clubfte.com/users/ratsmoker/FAQ.html
