1978 - 1996 Big Bronco
auto locking Hub Question
Old Jul 31, 2010 | 05:44 PM
wetneck's Avatar
wetneck
removed assembly,replaced rotor but ended up with this part during reinstall...
can someone tell me the sequence this goes back in ??
thanks in advance
Old Aug 1, 2010 | 01:20 AM
rudedogii's Avatar
rudedogii
Gee it's been a long time but I think that keeps the bearing adjuster nut locked in place. I think? I'll have to check my books and get back .
Old Aug 1, 2010 | 01:47 AM
rudedogii's Avatar
rudedogii
Yes
Thats the part I'am talking about.
I will try to post a link to the WARN web page with the diagrams. If it dosent post try going to the WARN web site and search by part #9790 and look at the installation instructions diagram for the WARN Autolock hub.
http://warn.iwebcat.com/imgVD/WAR/61420C0-pn9790.pdf
Old Aug 1, 2010 | 04:41 PM
wetneck's Avatar
wetneck
thanks, got it back together last night...
Old Aug 1, 2010 | 06:23 PM
Varkwso's Avatar
Varkwso
Keep it in good shape they are not available.
Original owner of a 95 Bronco with those still on the vehicle (auto locking died long ago - manual hubs now)
Old Aug 5, 2010 | 10:51 PM
JohnMcD348's Avatar
JohnMcD348
I still have factory Auto hubs on my 92. Is there any particular service interval that's recommended? I was wondering if I should dismantle and cleanup repack? About the only time I've ever dealt with anything like this was about 20 years ago when I had to replace a bearing in my 88 Samurai and I cleaned and regreased my manual hubs then. I always hear about how the auto hubs are bad but(knock on wood) these have never been a problem for me. I do drive down a soft dirt road a couple times a month in my Bronco and my Ram i order to "work the hubs" for a bit.
Old Aug 8, 2010 | 12:27 PM
wetneck's Avatar
wetneck
i got the auto locker all back together ok but i now have an issue where i get a knocking noise when braking from the side i replaced a rotor on, right side. i only hear when braking and one per revolution of rotor/wheel. i 2x reseated studs thru hub/rotor and didnt help.... pads are seated in caliper correctly....
any other suggestions on what my issue might be ???
Old Aug 8, 2010 | 05:34 PM
rudedogii's Avatar
rudedogii
Jack up the wheel thats making the noise and check the wheel bearnings by shaking the wheell side to side and top to bottom. Check for play.
Next check to see if any of the wheel weights are in contact with the caliper. You should beable to see the shinny wear spot on the weights.
I have the wheel weight problem evertime I get new tires.
Old Aug 8, 2010 | 06:07 PM
wetneck's Avatar
wetneck
jacked it this morning and felt no play... just both wheels at once, side to side...
it doesnt happen while driving just when brake is stepped on...
i replaced rotor and pads on rt front, thats where the noise comes from...
did left pads and all ok
pads are seated normally on caliper.....
thought it might have been the rotor not fully seating on hub with studs so redid it, beat the studs down as tight as i could with a hammer, used impact and spacers, then used impact on lugs.... and still same
going to try to have old rotor turned and replace the new with it as i dont know what else to try
im stumped
Old Aug 11, 2010 | 04:47 PM
wetneck's Avatar
wetneck
was the grooves in the new rotor that was causing the issue.... ground down the rotor and all fixed.... thanks for the suggestions !
propellerhead
15
Apr 25, 2017 12:28 PM
Raleigh1
682
Mar 18, 2016 01:29 PM
MOOSE_MACHINE
Testing.....
Mar 18, 2014 07:03 PM
postoak99
1997 - 2003 F150
Mar 5, 2011 11:05 AM
