I have a squeel coming under hood. I had a mechanic replace water pump, fan he cant find squeel it squeels about 80% of timt truck is running. Any ideas???? Thanks
while its running, take a spray bottle with a little water and shoot at the belt. if noise goes away, its the belt. if not, then idler bearing, tenskoner.. or even alternator.
