93' F350 Rear Pinion Nut torque?
Yeah I think I might have made more work for myself. But anyhow I never checked the torque on the rear pinion nut before I replaced the seal and I was wondering if there was a torque spec for it? Im not 100% on the type axle I have, but I can tell you its a 1993 7.3 auto with 8 bolt lugs and the rear diff cover has 12 bolts to hold it on.
Thanks guys.
Thanks guys.
Yep, that's the vent hose, should also have a little breather-thing at its top end - pull the breather off the hose and see if you can blow some air through with your mouth, but pull the axle oil fill plug first cause if you don't then the air you're pushing through the hose has nowhere to go and you won't be able to feel if there is resistance (plugged line) or free flow (all clear).
One should never over tighten then back off a pinion nut ... If you over tighten it, leave it or replace the crush collar.
Ultimately you should put a mark between the pinion and nut, remove nut, yoke, seal, replace seal, yoke, nut and tighten to aligned marks ...
-Enjoy
fh : )_~
-Enjoy
fh : )_~
Yep when i swap the yoke out i will do just that, seems just right!!
-Enjoy
fh : )_~
-Enjoy
fh : )_~
Anyway what sucks now is i already filled the diff and i gotta remove the plug... time to make another mess! If I can blow through it, can I blow air through it with a hose to un block it?
Dalek Sec
1983 - 2012 Ranger & B-Series
11-17-2013 03:59 AM
pikiluvi
11-04-2006 01:53 PM
