Working Ford Trucks Only
#1381
#1382
#1383
Have you noticed how long the antenna is? Was it for a two way radio?
#1384
I'm a little nervous for ya Dennis I've been a Firefighter for over 30 years and combustible to close to heating stoves, start a lot of fires. Just say'n. Main thing is you keep that stove pipe clean and always a fresh battery in your smoke detectors. Enough preaching. Is that white car a Pinto?
I have a hand fired Burnham boiler that we got into the basement before the walls were laid up. When it was below 0 this winter I bet I was burning close to 150 lbs a day. It’s probably not very efficient, but I like it. It was built pre 1940 because it says Irvington NY on the door. Burnham moved to Lancaster PA in 1940. 4 years ago I was able to get new grates for it. I burned firewood for 36 years. I don’t miss that.
#1386
#1390
#1391
#1392
1946 Ford Truck and Commercial Identification, Flathead V8, Model 69, 691, 694, 698, 6G - Restore Your Ford
and this truck looks similar. I don't see any evidence of tandem axles from my perspective.
#1393
#1394
Nice pic Abe! The Autocar trucks are late '40's In 1950 they went to the semi wrap-around split windshields. That same cab was shared with White, Diamond T, and a couple of others. I think it was a Budd cab. Is #57 the custom cab with the different grille? #56 has an air horn, suggesting it has air brakes. Curious, I thought the Big Job (Super Duty) trucks of the era had hood scoops. No? Wouldn't these trucks have the Super Duty big block engines? The biggest curiosity to me though is that none of the trucks appear to have marker or clearance lights. Hmm.
#1395
Yes, number 57 is the Deluxe Cab. It has the "teeth" that they used in 53. The term Custom Cab was not used until 55. The hood scoops were first used in 1956 and then only on the larger engines or the ones with the 4 barrel carb. And it is odd they did not have clearance lights on the cab. Heck I now have 5 on my F350.
I see now that #56 has an air horn. It looks like they painted everything red! I would think they all had air brakes. They would have had an air compressor on the engine. Wouldn't
they need air to run the water to rinse their chutes?
