Working Ford Trucks Only
#1126
Did you pull the travel trailer with your truck? How far did you go with it? That's what I intend to do. A month ago I start out on a trip with mt 22 ft 3700 lb. trailer but I didn't have the rear springs and rear air shocks set up right so I chickened out and turned back for home. I think it will work fine now that I've added 1.5 inches ofd arch to the springs.
[QUOTE=pintoplumber;16638275]Well, I had the old girl working this weekend. Dennis
/QUOTE]
/QUOTE]
#1127
I was told about this truck years ago and finally stumbled onto it about a month ago. It's at a truck repair shop about 30 miles from my house.
It's still working although it hasn't moved an inch in probably decades. The truck repair shop uses it to store used motor oil until it's picked up for recycling.
#1128
[QUOTE=das54;16642131]Did you pull the travel trailer with your truck? How far did you go with it? That's what I intend to do. A month ago I start out on a trip with mt 22 ft 3700 lb. trailer but I didn't have the rear springs and rear air shocks set up right so I chickened out and turned back for home. I think it will work fine now that I've added 1.5 inches ofd arch to the springs.
Dan, ours is 22' 4" bumper to tongue with a rear bed slide out. Loaded we weigh around 5400. I have a 4.27 rear 8 plies on the springs and 6 plies on the helper springs. Weight distributing hitch. 75 to 100 miles is as far as we've gone with it. The truck is pretty thirsty on gas. Dennis
#1130
#1131
Look what was done to my truck when my grandfather owned it. A thick piece of steel was cut out to frame the bed on two sides and the bottom beneath the tailgate.
#1132
I was thinking it was an attempt to make a sturdy bracket to support some kind of farm impliment.
#1133
Don't forget these trucks were mainly farm work trucks. My F3 was used to haul cattle to market, hay, manure, fertilizer and any other thing needed on the farm. The bed sides were rusted out along the whole side. It had angle iron supports similar to those also. We tend to baby these beautiful old beast and our ancestors used them like the trucks they are. Have fun
#1134
#1139
