keyless entry door code
Old Jul 28, 2010 | 05:11 PM
rotun's Avatar
rotun
Reads ***** rules!
Originally Posted by Headviking
They come with there own master number. After using the master number you program your own. The master number will never be overwritten or erased.
I thought I had read that before but wasn't sure.
Old Jul 28, 2010 | 09:29 PM
tofargone's Avatar
tofargone
I just got the number for both my 04 F-250 and my 02 excursion the excursion was ezer to find cuz there is no insolation but I new ware to look on the truck. but pull both the radio and the trash bag holder and slide out the cup holder. when you pull out the radio you will see a horisantal bar and behind the bar against the fire wall there is a black box with a bunch of wires going into it move the insolation so you can see the box and you can just see a sticker but no numbers get a light and shine it thru the radio hole and look thu the holder hole to read the sticker its a little chalinging to get the wright angle to see it but it can be done.
Old Jul 28, 2010 | 09:53 PM
swamp donk's Avatar
swamp donk
thanks for the help guys i will try it again this weekend when i have more time. hopefully i will get it this time. thanks again!
Old Jul 29, 2010 | 07:26 PM
tofargone's Avatar
tofargone
O when your looken thru the holder hole i did it from the pasenger side
Old Dec 4, 2012 | 05:15 PM
Diamnd1's Avatar
Diamnd1
I have a 2004 f250. I got an automotive mirror and flashlight and found the code on a black box behind the radio. I had to try the numbers beginning at either end as it is hard to tell which way the numbers read normally(eg,12345 or 54321). It worked.
Old Dec 4, 2012 | 07:13 PM
daddykitty's Avatar
daddykitty
num num num numnum num...what? num num num num num num
Old Dec 4, 2012 | 10:59 PM
Yahiko's Avatar
Yahiko
I have a easy way for you and you get a new handy tool out of it.
This is how you justify a new video bore scope to the wife.
On this I really lucked out in I already have the scope and
when I opened the owners manual I still had the card with
the code on it in the pocket in the guide.
Also next time you stop in to buy some parts or filters ask the
parts guy "By the way can you please"
Sean
Old Dec 5, 2012 | 04:25 AM
RigET's Avatar
RigET
Originally Posted by frt2599
I couldn't see it without the mirror and flash light. It's way up there. Get a mirror (automative with the extension) stick it up there and shine the flash light on the mirror. you will be almost standing on your head. I have a 2004 F250 and it was there.... found mine without removing anything.good luck
I also did not remove alot of stuff just used a mirror and a flashlight, got a good look at the first 4 numbers and had to guess at the 5th but that didnt take long.
Old Dec 6, 2012 | 02:04 PM
Stroker 6.0 fan's Avatar
Stroker 6.0 fan
Looked for almost an hour and could not find the box with the factory code. Finally took it to my local dealership and they put it on computer and retrieved the factory 5 digit code. Was told the later production 05's and on do not have the stickers with code on them anymore only pre 05 do. The code is in computer. It cost me $46 for them to get it.
Old Dec 6, 2012 | 02:29 PM
RigET's Avatar
RigET
It will be well worth it. I did not make the effort till I locked myself out of my idling truck while putting up yard sale signs on the side of the road, that was interesting!
Old Dec 6, 2012 | 04:34 PM
Mich6.0's Avatar
Mich6.0
Just make sure you change the battery every year or you will be in the same situation . I got locked out about a year after buying my truck, FORD COVERED THE CALL. And after that I change the battery every year
Old Dec 6, 2012 | 05:13 PM
T diesel's Avatar
T diesel
My 06 had the sticker.
Old Dec 9, 2012 | 01:38 AM
  #28
run6.0run's Avatar
run6.0run
Well guys,,, I had my batteries, and engine out for almost 2 1/2 months,,, and it remembered the code I programmed in it.
Also, I used my phone on video with the flash on and found it fairly quick.
Old Dec 9, 2012 | 10:11 AM
  #29
greentree ford's Avatar
greentree ford
I found an old post in the excursion site that has pictures( computers arent my strong point so no quick connect) IT is tittled KEYLESS KEYPAD CODE it is from 08-01-2006 There are three ways to find the code removing the radio is the hardest I found my buddies in less then five minutes. BY removing the fuse access panel by drivers knees and looking up at an angle behind the radio your looking for a 6x6 cream colored plastic box with a white sticker on it with five digits. It is good for 2002+ super duty and excursions
Brasson1999
Oct 10, 2015 07:43 AM
SolarKing
Jan 12, 2015 05:23 PM
fx4king2011
2009 - 2014 F150
Aug 30, 2014 09:21 AM
F350 king ranch
Sep 1, 2013 04:06 PM
pmaldon988
Jul 15, 2003 12:45 AM
