91 f 150 R 134a to R12
I have a 91 f 150. it has been converted from r12 to r134a xh7 kit. The air is not cold at all even fully charged with refrigerant. I have access to r12. should i convert it back to r12 or can i use the existing setup? would r12 be any colder? any feedback greatly appreciated.
Robert has a valid point. R-134a conversions do not work as well as the original R-12 but the vent temperatures should still be in the mid to high 40s on your truck. You really need a manifold gauge set to see what is going on. Your condenser could be plugged, poor airflow due to a faulty fan clutch or perhaps the fan shroud is also missing?
Let's hope you are not in the early stages of Black Death
PRyan1983
24
09-23-2015 01:11 PM
