Clicking noise when I accelerate - 03 Navi
Hi, my check engine light has turned on and I get a clicking noise when I accelerate. It only happens when I accelerate. I put it in neutral and I don't here it when I rev the engine. I hear it near the front drivers side and it is pretty loud. Almost a clicking and zipping sound. Any ideas? It is so frustrating and embarrasing to hear when I drive.
Reply -
Thank you sir!!
I just got a call from my mechanic and he said the clicking noise was due to a lose hose to the intake manifold. That got fixed!
The problem now is the check engine light. My mechanic tells me that we have a leaking vacuum. (WTH that is I don't know). He further states he needs to remove the intake to check if the leak is on the upper or lower manifold.
I am not sure if this is a big job or what I am looking at financially. Have you or anyone had to do this? Is this common or should I begin to look at trading this one in?
Any help or thoughts would help. Thanks!
To reseal the EGR at the back of the manifold is a bit of a job as 2 parts have to come off of the intake. One is an IMRC that is something like a secondary system in a 4 bbl carb and the second part is the upper half of the intake itself. After that it's pretty easy, then it all has to go back together.
Have it checked with a smoke machine before approving the repair and if your mechanic dosent have one, a local high school with a tech/automotive center may be able to determine where the leak is exactly.
I wouldn't be so quick to let him remove your intake manifold to look for a leak. I would first have him inspect the PCV hoses and fitting for additional leaks, as they can be the source of large vacuum leaks. There's a rubber elbow at the rear of the intake manifold that has been especially troublesome for a lot of people. It likes to crack and leak a lot of vacuum.
sprad1970
02-21-2017 03:07 PM
McKenzie7.3
12-18-2011 12:06 PM
