Can i swap a 170 for a 144 and bolt right in
170's were installed in 1960/72 Passenger Cars, 1961/70 Econolines and 1966/72 Bronco's.
The 144 is an anemic slug of an engine, barely has enough power to pull a sick trollop off a porcelain device.
144/170's have 4 main bearings, the 200 (first introduced in 1964 Fairlanes, used in Passenger Cars only thru 1983) has 7.
B&S: 144 = 3.50" x 2.50" / 170 = 3.50" x 2.94" / 200 = 3.68" x 3.13" / 250 = 3.68" x 3.91"
The 250 (also has 7 mains) was introduced in 1969, used in Passenger Cars only thru 1980.
If someone claims to have a rebuilt engine, ask to see the receipts for all the work done. No receipts = PASS!
66gpw: You sure that engine you got from the '70 Maverick is a 200? The 250 was also available.
The 200's bare block changed in 1968. The 250's bare block is different from a 200.
Yes it was a 200 that had been rebuilt. The fella owed me cash so I got the car from him. The motor had some miles on it, but less than 50,000 miles.
I had to drill another hole on the crossmember in my truck for it to mount in. The bell housing would not match. So I got an aluminum bell housing had it built up where I needed it to bolt on. But that was 13 years ago and never finished bolting it in, due to a family crisis. Now I like to go back to a 170 which I have in a parts van that was running at the time I bought it with the 4spd trans on it.
If it is not the 200 I was told at that time it was. How can a person visually tell the difference. I'm not up on engine building as much as I'm into the body work of vehicles.
